Dell Dimension XPS 400 PC Desktop Logo
Posted on Dec 14, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Boot sequence - Dell Dimension XPS 400 PC Desktop
Brian Sullivan
Level 3:
  • Dell Master 27,725 Answers
  • Posted on Dec 14, 2012
Brian Sullivan
Dell Master
Level 3:
Answers
27725
Questions
Helped
5776703
Points
79191
During the boot process you will a certain key to press to enter se up usually the Delete or F2 key this will vary depending on your operating system and computer Press and hold that key during the boot up process to enter BIOS using the arrow keys navigate to Advanced bios features press enter you will see the boot order Change the first boot device to your hard drive.
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ? If you are unsure or have made mistakes you can load optimised or failsafe defaults this will automatically set the boot order Hope this helps.
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
Boot sequence password
restart the computer and HOLD the keys CTRL or FN + f2 or ESC depend of your mark, model, and enter the BIOS setup select boot sequence and enable, and ready.
God bless you
Not booting into windows
Try pressing del on start up then you will go into BIOS SET UP when you're go to the boot sequence see if the hard drive is on the first boot sequence. If not change the first boot sequence into your hard drive .
I have acer aspire 3000+ and cant change bios setup to boot first from cd rom and erecovery doesnt work
Why can't you change the bios setup to change the boot order or boot sequence?
Also you can change the boot order or boot sequence temporarily by just rebooting the laptop then watch the screen for which key it says to hit to change the boot sequence or boot order, then hit that key when you see the message.
Winfast boot sequence problem
Boot sequence problem? You set the boot sequence permanently in the Bios or System Setup. Normally when you boot the system the screen will tell you what key to hit to get into the Bios or Systems Setup.
You can set the boot sequence temporarily (just for the current boot cycle) by watching the screen when you boot and it will tell you which key to hit to change the boot sequence or boot order.
1helpful
Toshiba Satellite Pro 4600 laptop
Just put the Recovery Disk in the drive and the system should start booting from it. If not, pay close attention to the screen and when it shows you which key to hit to change the boot order or boot sequence hit it. Change the boot sequence to read from the CD drive. This is a temporary change on the boot sequence.
If you want to make a permanent change to the boot order or boot sequence you will need to hit the key that says enter Bios or System Setup and change it there.
My Laptop is Satellite L505-S5990,After i change boot sequence from booting with CD rom to HD it won't effect changes.WHy is it this way>Any tips as to why it is so and how i can change boot...
Changing boot sequence.
Go to bios setting, click "F2" upon start up( when you read the bios and HD readout ). Choose the part boot sequence, click " enter" and choose what drive will be use first.
Save the settings upon exit.
Hope FixYa helped you out!
2answers
When I turn on my computer, it goes to a black screen and says, "Disk Boot Failure, Insert Disk and Press Enter". I am also seeing an Error Code BIOHD-2 and it say Warning no drive detected. Can you help...
Possible tha the PC is infected and has the booting sequence faulty , some files are lost. you must reinstall the OS , format teh drive , then install an antivirus and finally the PC harware drivers.
3answers
How to change boot for cd or hd
That is done in the bios.
you could also watch the boot sequencs and see if it says somthing along the lines "press F10 to change boot order"if so that is another option
If this info was useful please click
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
