Frigidaire GLTF2940ES Front Load Washer Logo
Posted on Sep 29, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is error code e5e - Frigidaire GLTF2940ES Front Load Washer
  • Official Brand Answer 4,342 Answers
  • Posted on Oct 02, 2012
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1495608
Points
5908
Hello jsw1993 - Typically error code E5E indicates that there is a communication problem. Base on the intensity of the issue, I suggest contacting a professional technician to accurately repair the unit. Technician will need to check the wiring between the main control board and the speed control board. Supposing that the wiring is bad, it has to be corrected. However if the wiring is good the main control board will need to be replace or if the problem is not corrected, the speed control board will need replacing.
2answers
How do you fix an e5e communication error on a frigidaire washing machine?
Hey friend, thanks for your inquiry!
I see your Frigidaire washer is displaying an error code "e5e". However, it appears "e5e" is an invalid error code. Let's attempt resetting your range. You can do this by unplugging it or flipping the household circuit breaker to the off position for roughly ten minutes. This usually clears false error codes.
If resetting the power does not correct the issue, could you please inform me of the new error code or if your dishwasher continues to display "e5e" you may want to seek assistance from a professional for proper repairs. -Matt
1helpful
What to do with err code e5e? help
Hi Friend, this is Z. Thank you for your question!
Typically error code E5E indicates that your Frigidaire washer is experiencing a communication problem. Base on the intensity of the issue, I suggest contacting a professional technician to accurately repair your washer. Typically, a technician will need to check the wiring between the main control board and the speed control board. Depending on the diagnoses and if the wiring is bad, it has to be corrected. However if the wiring is good the main control board may need to be replace or if the problem is not corrected, the speed control board is possibly faulty.
Frigidaire fafw3801lw3 gives an e5e code
Good Morning Eric, this is JK. I understand that you are receiving error E5E on your dishwasher. It appears the error code you are receiving indicates there may be a communication problem. Check the wiring between the Main Control Board and the Speed Control Board. If you find the wiring is good, you may need to replace the Main Control Board. If the problem is not corrected, consider replacing the Speed Control Board. Hope this helps!
Gltf2940fs
washer stopped working, displayed E5E error when prompted for code. I opened up the back of the machine and noticed that a connector was not connected to the control board, i removed the control board to get a better view of where it belonged, and slid the connector over the control board, closed up the machine and it's back in business.
Error code E5E
E5E is for the control board failure. Here is the replacement part.
All parts come with a 365 day, any part, any reason return policy.
1helpful
My frigidaire model is GLTF2940FE0 front loader will not start
I was wondering did u ever figure this out i have same code ...but mine will run a little water then drain and never spins but got the code E5E too
2helpful
2answers
I got an error code e5e from frigidaire front loader
Hello barnessursula - Typically error code E5E indicates that there is a communication problem. Base on the intensity of the issue, I suggest contacting a professional technician to accurately repair the unit. Technician will need to check the wiring between the main control board and the speed control board. Depending on the diagnoses and if the wiring is bad, it has to be corrected. However, if the wiring is good the main control board will need to be replace or if the problem is not corrected, the speed control board will need replacing.
Error # E5E
this is a communication error between the main contorl board and the speed control board check all the wiring harness and make sure they are in good order.replace the main control board if the problem continues replcae the speed control board
1helpful
Washer's tub will not move
I don't know what the E5E error code refers to but I can think of at least one possible reason for no motor action, even if motor itself is ok and board has been replaced. The relay itself could be faulty with no power from the output side, even if it clicks on. Less likely but still possible would be a faulty overload protector at the motor.
Top Frigidaire Washing Machines Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
