Frigidaire ATF6000ES Front Load Washer Logo
A
Anonymous Posted on Jul 10, 2014
What to do with err code e5e? help
Washer starts to fill, then nothing
  • Official Brand Answer 2,267 Answers
  • Posted on Jul 15, 2014
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1313570
Points
2558
Hi Friend, this is Z. Thank you for your question!
Typically error code E5E indicates that your Frigidaire washer is experiencing a communication problem. Base on the intensity of the issue, I suggest contacting a professional technician to accurately repair your washer. Typically, a technician will need to check the wiring between the main control board and the speed control board. Depending on the diagnoses and if the wiring is bad, it has to be corrected. However if the wiring is good the main control board may need to be replace or if the problem is not corrected, the speed control board is possibly faulty.
3 Related Answers
Anonymous
  • 679 Answers
  • Posted on Jan 10, 2011
SOURCE: i have a Frigidaire Gallery 3.5 Cu. Ft. King Size
it indicates a communication problem between the central main control and the motor speed control.
The two control boards are not talking to each other.
The first step to resolving this problem is to check the wire connections at each of the controls. The main control under the top panel and the speed control behind the rear panel. See the images below for help with this. Pull and push on all of the connectors.
Remember to unplug the washer first.
If all connections are tight then most likely the main control will have to be replaced.
If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician.
Anonymous
  • 15 Answers
  • Posted on Oct 10, 2007
SOURCE: frigidiare washer not doing anything
Before replacing check the voltage to the machine. Make sure the machine is not on any extension cord.when the machine is turned on make sure the voltage doesn't drop more than a few volts.
chrispolkele
Electrolux
  • 4342 Answers
  • Posted on Dec 17, 2012
Our people make the difference
    Verified Fixya Pro
    SOURCE: i got an error code e5e from frigidaire front loader
    Hello barnessursula - Typically error code E5E indicates that there is a communication problem. Base on the intensity of the issue, I suggest contacting a professional technician to accurately repair the unit. Technician will need to check the wiring between the main control board and the speed control board. Depending on the diagnoses and if the wiring is bad, it has to be corrected. However, if the wiring is good the main control board will need to be replace or if the problem is not corrected, the speed control board will need replacing.
    Top Frigidaire Washing Machines Experts
    Sudeep Chatterjee
    Sudeep Chatterjee
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
