Konica Minolta Copier Toner EP6001 CS Pro EP801550,000 Page Yield 8935-602 Logo
Posted on Sep 02, 2012
Error Code C0000 - Konica Minolta Copier Toner EP6001 CS Pro EP801550,000 Page Yield 8935-602
1 Related Answer
xeerie
Zaheer Ahmed
  • 347 Answers
  • Posted on Oct 18, 2010
SOURCE: error code c0000 in bizhub 210
Error code c0000 means imaging unit drive motor is not working or imaging unit get hard so its better to call a service representative.
2answers
Konica Bizhub 211. What does error code C0000 mean?
The code means there is some problem that requires a service technician to solve.
Tell me about toyota yars 2001 code , c0000
C0000 Vehicle Speed Information error.
How to remove C0000
C0000
Main Motor malfunction
- The Main Motor (M1) Lock signal remains HIGH for a continuous 1-sec. period at any time 1 sec. after the Main Motor has started turning.
Di450 Minolta Code 2510 erreur C0000
The C0000 code is that the Fusing Unit (The HOT Part) has a motor and it can not turn or is burned out do jam or gear problems. Could not find anything about 2510
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Error code C0000
Main motor not turning. Check for a major paper jam in the fuser unit. Open the front door and on the left side is the fuser assembly. Push in the green knob and turn the fuser. It should turn rather easily. If not it is jammed. That is the most common cause. Other than that you would need a technician to determine what assembly in the machine that has locked up and thus preventing the main motor from turning.
1helpful
Error code c0000 in bizhub 210
4helpful
2answers
Konica minolta bizhub 162 have error C0000(main motor malfunction) i try with another motor but same thing! any ideas?!
could be master board (pwb-a) or power supply unit (pu-1) or something that the motor turns is locked up try to you turn the motor by hand whil it is installed in the machine if you cant turn it by hand something is locked up
3helpful
2answers
Konica minolta d183 error code C0000
Main motor malfunction.Change the main motor and check the fusing unit.For reset turn OFF and ON the power switch,unpluged the cords and wait 10sec. pluged on and then ON the power switch.
2helpful
Error code c 00 00
DTC C0000 Vehicle Speed Information Circuit, I hope that helps. Link to 2004 Dodge Ram Service Manual
Identification of error codes
C0000 Main motor
c6000 scanner/lamp
C5000 fuser
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
