The code means there is some problem that requires a service technician to solve.
SOURCE: konica minolta bizhub 162 have error C0000(main
could be master board (pwb-a) or power supply unit (pu-1) or something that the motor turns is locked up try to you turn the motor by hand whil it is installed in the machine if you cant turn it by hand something is locked up
Testimonial: "yes this is right ! i figer out the problem - it was in development unit! tNx"
SOURCE: REMEDY TO SOLVING ERRORS COF32
C0650 code is the scanner lamp home sensor is not working so the copier does not know where the scanner is clean first will require removal of the orginal glass (large one) the other code is the image unit, has it been replaced or repaired recently. To fix mite require a new image unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: REMEDY TO SOLVING ERRORS COF32 AND CO650 IN KONICA
to remove code "COF32" from your machine, simply change the developer with the new one.
code will remove.
wish you best of luck............
SOURCE: error c03ff bizhub 211 konica minolta no se
model setting error :)
never change this setting.
if it changed,the Technical Rep.call (C03FF) will appear.
,default setting depend on the marketing area setting.
ex: 20ppm,18ppm,16ppm....
