Canon MP140 PHOTO AIO All-In-One InkJet Printer Logo
Posted on Apr 17, 2012
Mp140 error code 2,178,0 - Canon MP140 PHOTO AIO All-In-One InkJet Printer
1 Related Answer
Anonymous
  • Posted on Mar 02, 2008
SOURCE: Canon PIXMA MP140 error code E 2
error E 2 => The machine is out of paper. / Paper does not feed.
Reload paper in the Auto Sheet Feeder and press the Black or Color button.
Multifuncional mp140, result error 4,2 and then error 5010 solution?
canon mp140 i get a error code 5010 any suggestions on how to fix this?
5helpful
7helpful
MP140 can't recognise the black cartridge that I've just installed. Error code 4 - any ideas? I've tried the manual - nothing, and not much luck online - Thanks
Error code 4 normally indicates that there is no unk, and the solution is by installing a genuine cartridge, Try to use Black PG40 remanufactured Canon printer ink cartridge. This cartridge is a high capacity cartridge which has been filled with 23ml of ink compared with the 16ml (Black) that you get with the originals. Compatible with: Canon Pixma MP140. if this error still occur it is better that you try the following procedure below:-
When you insert a refilled ink cartridge into your Pixma MP140 printer you should get a warning about the refilled cartridge. You should also be prompted, asking if you wish to disable ink level detecting. Agree to do so, and you won’t get the warnings again because the ink levels won’t be monitored by the printer.
Thanks
3helpful
3answers
Mp140 problem
mp140 problem code: 2,155,0 ?????? first photo .. to repeat :S
soryy
2helpful
Replace with genuine cartridges is the best policy.
5helpful
Canon pixima mp140 error code E6
printer gak bisa ngeprin error E6 gai mana cara mengatasinya
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
