GTCO CalComp Drawing Board III 34480 Graphic Tablet Logo
A
Anonymous Posted on Apr 10, 2012
34480 calcomp model - GTCO CalComp Drawing Board III 34480 Graphic Tablet
2 Related Answers
William F. Bryant Jr
  • 49 Answers
  • Posted on Jul 19, 2011
SOURCE: Hi I have an Calcomp Drawing
You can get accessories from www.gtcocalcomp.com for your DB3.
Also try calling 1-800-digipad
Anonymous
  • Posted on Sep 17, 2011
SOURCE: GTCO CalComp Drawing Board III
First conform that serial port is selected as NONE on digitizer manager while you running the lectra tablet utilities. If you try this already please check your cable connectivity any one of the line may be missing connection. It may work but you can't able to run lectra tablet utilities.
Does the drawing board III use WinTab for arcGIS 10?
ALL ESRI ARC Programs as far as I am aware use the Standard GTCO Tablet Works drivers. All GTCOCalcomp digitizers are or were level 1 supported by ESRI and the standard tabletworks driver will work just fine (This only applies to Windows versions of ARC, not Unix or other OS's)
Drivers can be obtained from GTCOCalcomp or from this link at the Interworld Site: http://www.interworldna.com/GTCO/gtco-drivers.php
If your digitizer has a serial interface use the SuperSet code 01 or 11. If you digitizer uses USB then no superset is active or needed (This only applies to GTCO or GTCOCalcomp Digitizers)
Calcomp or Summagraphics digitizers will need to be set to 9600,8,N,1 with High Resolution Biinary output to work with Tablet works. Hope this helps you
2helpful
GTCO CalComp Drawing Board III 34480 Graphic Tablet.lectra tablet utilities is not running
How do you uninstall tabletworks on an xp machine when it doesn't appear in the add/remove programs list - help! tabletworks works fine it just doesn't work with autocad lt and we need to get rid of it
Control Panel / System / Hardware / Device Manager / identify the tablet and double click on it / 1 - in General, at Device usage put it to disable and disconnect it / 2 - in Driver Uninstall it.
We have a Calcomp Techjet 5424 printer. We got it
I have the same plotter and use canon BC-02 cartridges they work fine although they can be difficult to find, have you tried refilling the empty cartridge yourself it's easy piezy.
2answers
GTCO Calcomp Drawing Board III connects but won't function...
I HAVE CALCOMP DRAWING BOARD II BUT MISSING ALL CONACTION FOR IT ( CHARAGE , POINTER , 1/O )
PLEASE WE NEED PAY THIS CONACTION FOR RUN
MY EMAIL SAYEDTEBBIN@YAHOO.COM
If you need documentation, go to GTCOCalcomp.com and they have FREE documentation for your tablet.
It may be a software switch is turned on and is causing this problem. Also check the driver and turn off any mapping.
When you read the manual it will show you how to turn off/on the software switches on the tablet.
These tablets should boot-up in the GTCO binary mode.
1helpful
This tablet,when turned on,should only beep once.
It sounds like their may be a hardware problem or corrupt firmware.
Make sure you are using the correct power supply, these use a 12 volt power supply,center negative.
If this fails contact GTCOCalcomp Tech Support.
Top GTCO Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a GTCO Computer and Internet Expert? Answer questions, earn points and help others
