GTCO CalComp Drawing Board III 34480 Graphic Tablet Logo
Posted on Jul 06, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tablet not found
My drawing board has been working fine for years. Now suddenly my computer doesn't seem to recognize that it's still there. If I open TabletWorks it says "couldn't find tablet". I've rebooted and shut down the computer (this has worked for me in the past) - nothing! The only thing that I changed recently was the addition of a new HP L1908w monitor. Could that have anything to do with my problem? Doesn't seem very likely to me!
  • Anonymous Sep 16, 2008
    I'm going through the same thing. My problem started when we replaced the lexan cutting surface on our plotting table. The static electricity zapped our Drawing Board.
  • lennondogg Jan 06, 2009
    I have the same problem, I didn't change anything, my computer just stopped "seeing" the board!
Marvin
Level 3:
Top Expert:
  • GTCO Master 85,242 Answers
  • Posted on Jul 06, 2017
Marvin
GTCO Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29677566
Points
266298
The tablet has failed.
4 Related Answers
Azrael SRL
  • 11800 Answers
  • Posted on Mar 01, 2010
SOURCE: how do you uninstall tabletworks on an xp machine
Control Panel / System / Hardware / Device Manager / identify the tablet and double click on it / 1 - in General, at Device usage put it to disable and disconnect it / 2 - in Driver Uninstall it.
Anonymous
  • 3278 Answers
  • Posted on Mar 31, 2011
SOURCE: GTCO Roll-Up II digitizer suddenly
Hello.
There may be a problem with the GTCO Roll-Up II driver (software to run the tablet).
Here is a link to find the driver, in case you don't have a copy.
http://www.getdigitizers.com/Roll-Up-Digitizer_c_109.html
Select Drivers next to Roll-Up II and Save then Run the TW-10.9.24 file.
If not the driver, then check the ribbon cable connections on both ends. Disconnect and then reconnect the ribbon cable to be sure it is seated well. Then press the reset button on the controller.
If still a problem, check this printable Help file, if you don't have a copy of the User Guide:
http://www.gtcocalcomp.com/files/rudii.pdf
Hope this helps.
Anonymous
  • 51 Answers
  • Posted on May 28, 2011
SOURCE: When I'm using Photoshop CS4
Go to Control Panel, and open bamboo properties. There you select the "pen" tab. In the pen tab you will see tracking. Select pen mode and details. You can map the pad there. After mapping pen mode try it in mouse mode as well. Best of luck!
Anonymous
  • Posted on Sep 17, 2011
SOURCE: GTCO CalComp Drawing Board III
First conform that serial port is selected as NONE on digitizer manager while you running the lectra tablet utilities. If you try this already please check your cable connectivity any one of the line may be missing connection. It may work but you can't able to run lectra tablet utilities.
Top GTCO Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a GTCO Computer and Internet Expert? Answer questions, earn points and help others
