Replace the drum unit.
Description:
Follow the procedure below to replace the drum unit.
The Brother machine has separate consumables the toner cartridge and
the drum unit. Verify you replace only the drum unit and not the toner
cartridge. If you want to know their difference, refer to "What is the difference between the toner cartridge and the drum unit?"
Caution
Do NOT use flammable substances near the machine. Do NOT use any type
of spray to clean the inside or outside of the machine. Doing this may
cause a fire or electrical shock.
Caution
Caution
Note
Discard the used drum unit according to local regulations, keeping it
separate from domestic waste. Be sure to seal up the used drum unit
tightly in a suitable bag so that toner powder does not spill out of the
unit. If you have questions, call your local waste disposal office.
Caution
Caution
Make sure that you put in the toner cartridge properly or it may separate from the drum unit.
Caution
BHow can I remove the drum from the printer? - replacedrum_05.gifhe green tab to the home position (1). If you do not, printed pages may have a vertical stripe.
For MFC users:
To confirm you are installing a new drum, press 1.
For DCP users:
To confirm you are installing a new drum, press the Up Arrow key.
CAUTION:
Do not touch the surface of the roller or expose the roller to light for an extended period of
time. Doing so could cause print-quality issues.
