Video Cameras Logo
Help me!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! please...
I have fully charged my kodak camera and I have even tried turning it on and off it just wont work what I am doing with my camera is very very very important and since my camera isnt working I have nothing to use for this important family gathering and in this case,I just wanted to ask you,what do i do in a situation like this very important gathering.
  • just letting you know that my camera is a kodak shockproof and waterproof play sport DIS camera
    ~THANKS~
5 Related Answers
Anonymous
  • 1476 Answers
  • Posted on Jul 25, 2006
SOURCE: Camera will not turn on
Remove the battery for about 30 minutes. This will reset the unit and if it is a software issue it should be OK. You can also try it on the AC adapter in case the battery connector is defective. If reset allows it to work on AC but not battery you have a problem with the DC input connector. If you are good with your hands, have jewelers screwdrivers, magnifying glasses, a steady hand and lots of patience as well as good soldering skills you can remove the cases and repair the input connector. If you are not confident about doing this you will need to seek the help of a reputable repair shop. Hopefully, removing the battery and resetting the unit will solve your problem. Good luck.
Anonymous
  • 80 Answers
  • Posted on Feb 25, 2007
SOURCE: The batterys are charged, but nothing happens when I turn it on.
This camera and the model before it have a problem with inrush current opening a safety fuse on the DC-DC converter board. If this is the case, JVC will replace the SMD fuse with a modified part number, this should resolve the problem. Please be sure the camera is off before attempting to change the battery, this can also cause this problem. Good Luck. Joe Weibel customelectronics.org
Anonymous
  • Posted on May 06, 2007
SOURCE: my kodak c743 isnt working
PLEASE NOTE A COMMON PROBLEM WITH C743 IS THAT IT REQUIRES MORE POWER TO TURN THE CAMERA ON, IF YOU ARE USING THE KODAK ALKALINE BATTERY THAT COMES WITH YOUR CAMERA, PLEASE REPLACE YOUR BATTERY. TRY THE KODAK RECHARGEABLE BATTERY PACK(KAA2HR). THE KODAK RECHARGEABLE(KAA2HR) HAS MORE CURRENT CAPACITIES AND ARE MORE EFFECIENT. YOU CAN REFER TO YOUR USERS GUIDE ON THE APPENDIX SECTION FOR BATTERY INFORMATION. IF YOUR CAMERA IS STILL NOT TURNING ON, SEND IT TO A REPAIR CENTRE IF YOUR CAMERA IS STILL UNDER WARRANTY.
Media Man
  • Posted on Jun 16, 2008
SOURCE: the camera function will not work
Hey Uttado,
Check to see if the stanby lever that surrounds the record switch on the back of the camera has inadvertently been put on standby. If this has happened, the VCR will work but not the camera. Move it off of lock to standby and it should crank right up.
A
Anonymous
  • Posted on Jul 21, 2008
SOURCE: logitech pocket digital camera
Same happening to me. The solution is to try it in a different USB port, as it is a USB related issue.
Top Kodak Video Cameras Experts
Tony Parsons
Tony Parsons
ENFORCER
Are you a Kodak Video Camera Expert? Answer questions, earn points and help others
