HP LaserJet 5100dtn Printer Logo
Posted on Sep 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code 57.1 - HP LaserJet 5100dtn Printer
Vinaya Kumar Kuchipudi
Level 3:
  • HP Master 1,124 Answers
  • Posted on Sep 13, 2011
HP Master
Level 3:
Answers
1124
Questions
Helped
460042
Points
2591
Fan not rotating, open top & feft cover, manually rotate it, is it free or jammed ?,if its jammed,remove the fan, lubricate it or replace it.. check fan connector.
My Teka DW7 57 FI VRO2 dishwasher shows the error code E4.
E4 means it is overfilled because of too much inlet water. Turn off the main supply. Remove excess water from the base pan and restart the dishwasher. DW7 57 FI Teka official website Bathroom Kitchen Professional Kitchen and...
Apart from using the manual instructions, you can get technical help from the company directly too.
Hope this helps!
May 15, 2016 • Dishwashers
57.01 error
You do not state which HP printer you have but the 57 errors all indicate a problem with one fan or another. For instance, on an M4345 the 57.01 error would indicate that the cooling fan for the DC controller is not working.Here is a list of 57 errors by model Hp Error Code 57 Service Errors Codes 57 Tech Support
Error code 57
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Unit switches off and displays error code 02-57
According to:
bassfisherman60
From the manual
02-57 Fan lock
This code is output when fan locking (over 30 seconds) is detected.
After the error message is displayed, the power turns off.
Perhaps opening the unit with the power unplugged (of course!) and clearing/cleaning the fan would help. It may be that the fan is just clogged with dust/debris.
Toshiba dvd recorder error code
According to:
image_icon_name.gifbassfisherman60
From the manual
02-57 Fan lock
Laserjet error
57 errors refer to fan failure, 57.7 is the "optional duplexer fan failure"-if that is your code rather than 57.07, you will need to replace the duplexer.
2answers
Error Code F1 -57, and clues, solutions? Thanks, Don
F1 errors have to do with the finishing section. My code list doesn't go as high as 57.
Check to see if the finisher is connected properly to your copier. You should turn your copier off while inspecting it.
QUEStion About Sony KDP57XBR2 57" rear projection High Def PiP 1080 TV>>>>
5 flashes is IK or current to cathode. check the IC's on the crt boards, check the focus block, check the vertcal deflection IC since the IK pulses come from the verticl cicuit.
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
