Jenn-Air JBL800 Work Top Blender Logo
Posted on Aug 13, 2011
How do i get the bottom off the blender jar? - Jenn-Air JBL800 Work Top Blender
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 27, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1192
Points
The best way that I've found to remove the bottom from the blender jar is to put the blender jar back on the blender base (make sure it locks in place) and then turn the jar to the right. You'll feel the jar detaching from the base. Once it's loosened up, remove from the base and finish turning the bottom, manually. Before I found this method, I had tried everything to get the plastic bottom detached from the jar. Without removing the bottom, there's no way to clean it properly and rather than be unsafe I'd need to throw the whole works in the trash. But the method I've described above works every time!
5 Related Answers
Anonymous
  • Posted on Nov 20, 2007
SOURCE: Jar blender blade bottom screw on piece
villaware 1-866-484-5529
Anonymous
  • Posted on Jan 04, 2009
SOURCE: my blender's jar is broken, i want a new one
You might need to order one from the UK and pay delivery charges? I am based in the UK and it is tricky finding this part, but I think possible. I smashed my blender measuring jug this morning and I hope I can get a new one at viewpointdirect@aol.com - just placed an order. You don't mention a model of yours but the one I found is compatible with several makes - check out this link http://www.viewpointdirect.co.uk/philips-measuring-jug---for-use-with-hand-blenders-573-p.asp. They deliver worldwide for a reasonably high charge. Else there are some other jugs you can find, without pictures though, which might be compatible with your make, at http://www.buyspares.co.uk. Good luck!
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Mar 25, 2009
SOURCE: replacement blender jar
This is straight from the manufacturer:
Canada - Warranty Information
If your appliance is within the warranty period and you are experiencing difficulties please contact us 800-688-1989 or e-mail us at Customer Service. The Back to Basics Web site currently accepts and ships orders within the continental United States only.
Do you have any friends in the US that you could ship to? It would probably be prohibitively expensive compared to the cost of a new one.
co7196
Ned C Cook
  • 3433 Answers
  • Posted on Jul 21, 2009
SOURCE: blender leaks
Well, that's not good. Call the manufacturer and they should be willing to dend you one. Good luck.
Anonymous
  • 38 Answers
  • Posted on Nov 09, 2009
SOURCE: Blades on inside of kitchenaid blender jar won't turn.
look on ebay for a replacement second hand unit
Krups blender switch lights, but motor doesn't turn
Hi I take it that the bottom was not screwed tight when the milk spilled. Try unscrewing the bottom, take it apart and clean it in warm water and mild washing liquid . Put it together again and screw tightly. And off it should go.
kolbrun
My blender leaks at the base of the carafe
A couple of things you can check.
Unscrew the glass jar from the bottom.
Check to see if the grey seal is between the metal blade assembly and the glass jar. I had this issue and it turned out to be that a friend had reassembled the blender jar parts after taking it apart to clean it.
Leaking
Unfortunately Kitchenaid's design on those blenders is a one piece unit, over time the seals wear out and you have to replace the entire jar assembly, they usually run 40-50 dollars and can be found from several vendors.
Here is a link to the replacement jar on our site: KitchenAid Blade Jar Assembly W10555711
2helpful
Leaks from the bottom of the glass jar. Bought a new gasket and it is worse than ever.
Are you sure you are installing the gasket correctly?
Leaks are usually the result of a misaligned or cross-threaded blender jar base or from the gasket being installed incorrectly. Make sure the gasket is installed between the blade assembly and the screw on base.
If this does not help, please reply or repost.
1helpful
I have a kitchen aid blender with a polycarbonate jar. The jar leaks at the blade. I noticed it has a plastic nut on the bottom with left hand threads. However the nut will not fit over the drive gear...
Older KitchenAid blenders had a jar that was made so the blade assembly could be removed for cleaning. On the newer models the blender jar and the blade assembly are all one unit so you have to purchase a new jar to get the blade assembly. All of this is dependent on which model of blender you have.
We would be happy to help you. Please a give us a call at 1-800-339-9297 we would be happy to help! One of our repair technicians can talk you through the repair over the phone free of charge. On the bottom of your blender is the model and serial numbers; have these handy when you call so we can help you order the correct part.
We have several blender jars on our Web site http://www.mendingshed.com/kitaidblen.html for KitchenAid blenders. If we don't have the blender jar that fits your model in-stock we can order it and ship it to you. Please contact us with any further questions. You can also email your model number or questions to customerservice@mendingshed.com
Sincerely,
Mendingshed.com Staff
KitchenAid Blender Model KSB560GC0. Coupling is ruined. Looks to be a geared part at the base of the unit. [ top of motor ] Also there is a part that is geared at the bottom of the pitcher, attached to...
the older glass jar blenders were sold as a complete ***'y too.
no separate parts were available. i'm sure the stainless jars are sold in the same way...complete.
2helpful
3answers
There is a leak in the caraffe(or jar). It is at
Common issue with all of these carafe's. Once the jar starts to leak the bearings are shot and it is time to replace the jar. The bearings are non-replacable. Bad design in my opinion. I was able to get my last jar (I have been through 3 before the 5 year warranty went out) to last by hand washing and not putting it in the dishwasher, but after 4 years of use on this jar it failed too.
2answers
Top Jenn-Air Blenders Experts
ADMIN Andrew
ADMIN Andrew
Pieter Vleeshouwers
Pieter Vleeshouwers
john h
Are you a Jenn-Air Blender Expert? Answer questions, earn points and help others
