20 Most Recent
Used Hp Photosmart C4780 All-in-one Printer Questions & Answers
Airprint
Your printer has to be AirPrint compatible in order for you to be able to print directly from your iPhone and iPad.
1/24/2015 12:38:47 AM •
Used Hp...
Answered
on Jan 24, 2015
Www cartridgesupport com
What could have happen was that you refilled it when it was emptied dry, usually this spoils the cartridge. I would recommend you buy a new one and when its about 80% empty that's the time to refill, not after.
5/10/2013 1:45:50 AM •
Used Hp...
Answered
on May 10, 2013
Measuring for stair carpet
measure the length of the tread and riser, combined. Typically this will be 17 inches or so. Add at least an inch or two for good measure then, assuming all the stairs are the same, multiply by the number of stairs and, in most cases add for one additional riser. This is for straight stairs with no landings or turns. For pie-shaped stairs one needs to measure the longest points for the trad portions.
Flashing orange lights and it's saying F-05
"F-05" with flashing orange lights is used by many different appliances, so I need the brand and model to identify the fault correctly.
Please send:
Brand
Full model number
What type of machine it is (washer, boiler, coffee machine, etc.)
A photo of the display/lights would help too.
Ricoh Aficio MP W5100 Mono Wide Format MFP Printer Scanner. It shows ERROR J006?
Lots of information here plus Service Manuals. It is a Paper Jam or Transport issue.
https://www.google.com/search?q=AFICIO+MP+W5100+ERROR+J006The Aficio MP W5100 error J006 indicates an original document jam in the Auto Document Feeder (ADF/ARDF), specifically often caused by a transport motor failure or binding in the drive belt area.Scribd +1Immediate Troubleshooting StepsClear the Jam: Open the ADF unit cover and remove any jammed originals.Check Originals: Ensure the documents are not folded, torn, or stuck together, and are suitable for scanning (not too thick or flimsy).Check Drive Belt (Technical): If the error persists, the ADF Idler Pulleys and Shafts may need cleaning and lubrication to relieve binding.Restart/Reset: Turn the main power off and then back on to clear the error.Scribd +3If the issue continues, the ARDF drive belt or transport motor may need professional service.
