20 Most Recent Dell Latitude C640 Notebook Questions & Answers
Bios password forgotten
Here's a link to the Dell support article you need to try... Knowledge Base
5/8/2017 11:54:04 AM • Dell Latitude... • Answered on May 08, 2017
Dell latitude c640 restore to factory settings
2/23/2016 12:35:42 PM • Dell Latitude... • Answered on Feb 23, 2016
MY dell tatitude c640 battery is not charging, it power by AC (meaning the charger), the battery is charging in another latitude c640 latop. what is the fault, and how can i repair it
chances are the actual power jack in the laptop has gone bad. this is a common issue with lots of laptops and every dell laptop (4) that i have owned http://www.ebay.com/itm/like/281152320878?ul_noapp=true&chn=ps&lpid=82
11/19/2015 3:54:07 PM • Dell Latitude... • Answered on Nov 19, 2015
3answers
"Diagnostic Boot Selected" problem on power-up boot
its the problem with the keyboard. make sure Function key is not pressed while turning on the computer. normally it happens only then. if the problem presists try reseat the keybaord. to see how to reseat the keyboard.
NOTICE: Disconnect the computer and any attached devices from electrical outlets, and remove any installed batteries.
NOTICE: To avoid ESD, ground yourself by using a wrist grounding strap or by touching an unpainted metal surface on the computer.
  1. Remove the hard drive.
  2. Turn the computer over, and remove the five M2.5 x 12-mm screws labeled "circle K."
  3. Turn the computer over and open the display.
NOTICE: The keycaps on the keyboard are fragile, easily dislodged, and time- consuming to replace. Be careful when removing and handling the keyboard.
  1. Remove the center control cover:
  2. Insert a small, flat-blade screwdriver or plastic scribe into the notch at the right end of the center control cover and pry up the cover.
  3. Lift the center control cover up and away from the bottom case.
  4. To release the keyboard from the palm rest, use a small, flat-blade screwdriver or plastic scribe to pry up the right edge of the keyboard near the blank key.
  5. Lift the keyboard straight up about an inch and then rotate it forward toward the front of the computer, until the key face is resting on the palm rest.
NOTICE: Do not pull on the keyboard flex and track stick cables.
Pull up on the keyboard connector to disconnect it from the keyboard interface connector on the system board.
Remove the keyboard from the bottom case
See the images below for ready refference
To repalce the HDD see the image below
I am sure this will fix the computer. Because in this you are reseating the HDD as well. all the best.
3/15/2015 8:09:38 AM • Dell Latitude... • Answered on Mar 15, 2015
Lighten screen latitude e6400
flux program is all you need
10/3/2014 5:46:04 AM • Dell Latitude... • Answered on Oct 03, 2014
Display Overheat
its an older lcd screen. so try to replace the screen or get a notebook cooler to cool it.
6/20/2014 5:28:07 PM • Dell Latitude... • Answered on Jun 20, 2014
F1 is not aveliable
Hi mydear921 , What OS is installed on this system? Have you tried holding down fn key and then tap f1 key once. Let me know if that worked.
2/21/2014 7:13:48 AM • Dell Latitude... • Answered on Feb 21, 2014
How to change battery on Dell latitude c6400.14inch laptop
Hi, I think the Laptop you have is E6400, Steps to Remove the Battery. They are 3 Release Latches to remove the Battery. 1) Make Sure all cables including Power cord is unplugged. 2) Please look at the image attached. 1a2dca20-03d2-447a-9f36-95e42448fc94.jpg 3) Turn the Computer Upside Down. 4) I have numbered the Latches. Latch# 1 - Slide the battery door release latch# 1 into the unlocked position and Slide the battery door release latch# 1 toward the base of the system. 5) Latch# 2 and 3 - Slide the battery release latches into the unlocked possition. 6) Open the battery door on Latch# 1 8fb82f54-c0f2-4a79-91b3-fc98bf056f62.jpg 7) Using the battery pull tab slide the battery out of the system. Let me know if you need any other help. Thanks
2/21/2014 5:09:52 AM • Dell Latitude... • Answered on Feb 21, 2014
0answers
0answers
My laptop battery only charges to 70% now, but my
Hi, It really prolongs your battery life. I would recommend to keep it this way, while I don't know where to find the menu option to change it back.
12/2/2013 8:13:34 PM • Dell Latitude... • Answered on Dec 02, 2013
Running slow
your System may be slow due to following reason - Too many programs running at startup or in the background- Data Corruption, hard disk fragmentation- Missing Windows updates or outdated drivers- Not enough hard drive space, too many unused programs- Left over programs, old cached and temporary filesSo Follow these steps to fix computer problem::- Delete all the temp files- Remove unused programs- install latest drivers from the manufacturer site- Install and run antispyware software- Free up wasted space with Disk Cleanup tool- Defragment your hard disk driveIf you are unable to perform above tasks then use a single utility tool like PC Fresher that will fix windows errors that cause of system slow
9/30/2013 2:02:40 PM • Dell Latitude... • Answered on Sep 30, 2013
2answers
Upside down screen.
Press either Ctrl+Shift+DownKey
or it may be the UpKey. Try both :) one of them will get your screen back to normal
4/13/2013 3:17:18 PM • Dell Latitude... • Answered on Apr 13, 2013
2answers
The ethernet controller on my Dell Latitude
If you are using Windows XP, go to Control Panel > Network Connections. Right click on Local Area Connection and then click Enable. (This is only applicable if the ethernet port is disabled).
Also, you may go to Device Manager (Right Click My Computer > Manage > Device Manager) and then check if the ethernet is disabled or has a question or exclamation mark.
If both dont work, your ethernet controller is broken.
4/8/2013 8:13:39 AM • Dell Latitude... • Answered on Apr 08, 2013
Dell Latitude C640 Notebook Logo
399 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
LATITUDE Dell
  • LATITUDE Dell
Most Popular Question
c640 compltely dead
  • Computers & Internet
