20 Most Recent
HP Compaq Presario 2200 Notebook Questions & Answers
Im trying to listen to music at school but
streema.com or streama.com they can stream your local radio stations...but no guarantee, school districts are always finding new sites to block everyday, so it may be blocked in your district by now!!
2/9/2018 6:35:14 PM •
HP Compaq...
Answered
on Feb 09, 2018
Webcam driver hp hd-2200
You will probably have to delete the driver from the driver property page. Then reboot the computer. Then make sure there's no driver listed. Then select up the driver. Select that you have the driver. Find a driver. Install.
9/12/2017 8:17:38 AM •
HP Compaq...
Answered
on Sep 12, 2017
Wireless connection wont work
To check if the wireless card is bad or OK.
Go to Control Panel - Network Connections - Is the wireless network connection listed and if so is there a red X on this connection?
If so, right click on the wireless and click Repair - this may fix your problem, it forces the wireless router to issue the wireless card with a new IP address.
If it doesn't fix the problem then go to Control Panel - System - Hardware tab - Device Manager - scroll down to Network Adapters and expand and check your wireless card, is it Working and Enabled?
If has a yellow ? against it or not working then reinstall the wireless card driver.
If the wireless card is built-in check the BIOS to see if the wireless card is enabled, if not enable the wireless card and repeat the above steps.
If this doesn't fix your problem then the wireless card is faulty and you need a new wireless card. You can get a PCMCIA wireless card to replace the faulty wireless card. If the wireless card is built-in then disable the faulty wireless card in the BIOS before you install the new wireless card.
10/21/2013 4:13:54 PM •
HP Compaq...
Answered
on Oct 21, 2013
CMOS battery on Compaq Presario v2000
Desktop PCs use a battery to keep time when the they are off, much like a watch. Like a watch, the battery needs to be replaced when it runs low on power. Replace the battery using the steps below.
Unplug all cables except for the power. Write down each cable location if you do not already know where it connects.
Unplug the power cable and with the power cable removed press the Power button on the front of the PC.
Remove the screws on the rear of the PC.
Slide the side panel off from the rear of the PC.
Locate the battery. It is a small shiny round metal wafer (like a larger version of a watch battery).
Remember which direction the battery is installed. Usually the engraved side, the positive side, is face up. Remove the battery from the main board.
Acquire the battery and replace it in the same socket it was removed from. Make sure the new battery is installed in exactly the same orientation as the previous battery. (Warning: There is danger of explosion if the battery is not correctly replaced. Replace only the same or equivalent type of battery.
Replace a side panel by matching the side panel tabs with the tab openings in the case.
Connect all cables and turn on the PC to set the time.
Hope this helps. Would appreciate if you rate it. Thanks.
8/15/2012 3:35:28 AM •
HP Compaq...
Answered
on Aug 15, 2012
My laptop touch pad not working so i want to touch cable\
Click Start/Control Panel andlook for the Mouse and open it to check the mouse properties. Make sureyou don't have the touchpad disabled.Some models will allow you to toggle the touchpad on or off by clicking on thebutton that is located at the top of the touch pad in the middle.Some models will allow you to toggle the touchpad by tapping twice in the upperleft hand corner of the touchpad.Some models will require a keystroke to toggle the touchpad. Press andHold the ALT or FN function key located at the lower left portion of thekeyboard, then hit the key that toggles the touchpad. The correct key tohit will have the icon of a finger pointing at a square that represents thetouchpad.Download and reinstall the touch pad drivers.Get online and got towww.google.com In the google search box type: "Dell Support"(without the quotes and put your manufacturer name before Support). Lookfor downloads and drivers. Enter your model number and operating system whenrequested. Download and install the Touchpad drivers.
5/29/2012 9:51:54 PM •
HP Compaq...
Answered
on May 29, 2012
