20 Most Recent Sharp DM 2010 Laser Printer Questions & Answers
The copies has a ck or ch message and won't copy.
please check that all the door switches have been made and the front cover closes properly. Also ensure that your toner box unit is properly inserted.
1/8/2013 9:57:54 AM • Sharp DM 2010... • Answered on Jan 08, 2013
Sharp dm 2010 Unable to connect printer function.
you may need to tell the installation program that you are connecting via serial port. Com 1 usually.
6/21/2009 11:26:02 PM • Sharp DM 2010... • Answered on Jun 21, 2009
3answers
Have an older Sharp EL-1801Piii. I need to program a tax rate of .08917. How do I do that?
Here is the manual link Press CTRL+F Type in 'tax' top right, press Enter. Scroll through the 19 mentions, Number 3 shows it. Copied and pasted below, but it doesn't show symbol image. The first paragraph covers getting into setting mode and setting date and time, then comes 'Tax Rate'. https://www.manuallib.com/download//SHARP-EL-1801PIII-OPERATION-MANUAL.PDF GT • RATE SET GRAND TOTAL / RATE SETTING MODE SELECTOR: "GT": Grand Total "•": Neutral "RATE SET": To set the date, time, and tax rate, set this switch at the "RATE SET" position. Date: • Enter in the order of month, day and year, then press to complete the entry. • Use to separate month, day, and year. • When is pressed, the number entered is evaluated and displayed as "date" if the value is within the following range; "Error" is displayed otherwise, and the previously set date is restored. Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits) Time: • Enter in the order of hour, minutes, then press to complete the entry. (There is no entry available for the seconds value. The clock starts at zero second.) • If the hour/minute digit is less than 10, it is not necessary to enter the first digit "0". • Use to separate hour and minute values. • When is pressed, the number entered is evaluated and displayed as "time" if the value is within the following range; "Error" is displayed otherwise, and the previously set time is restored. Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59 Tax rate: • Press three times, enter the tax rate, followed by . • A maximum of 4 digits can be stored (decimal point is not counted as a digit). • Only one rate can be stored. If you enter a new rate, the previous rate will be cleared. more here and videos https://www.google.com/search?q=sharp+el-1801piii+set+tax+rate ..
10/3/2025 10:58:04 AM • Sharp Office... • Answered on Oct 03, 2025
Sharp Copier. I need the error codes for Sharp copiers please.
Question edited for clarity, but no MODEL given.
Question moved from Misc category, to Sharp.
Information for error codes
Sharp Global https://global.sharp > pdf > ERR_Message_EN PDF 002-500. An error occurred during the scan job. Execute the operation again. Also, check whether or not the account limit for the. Scan service is set. 003-311. 114 pages
Sharp Error Codes List
CopierRental https://www.copierrental.com > post > sharp-error-code... Apr 11, 2022 - Improper cartridge (life cycle error, etc.) Check Toner and Crop - Change toner if required. F2-05. CRUM error. Check Toner and Crop - Change . ..
5/15/2025 3:51:23 PM • Sharp Office... • Answered on May 15, 2025
2answers
CODE ERREUR F3-22 pour Sharp MX-7090
Question edited for clarity.
Question translated to English, we only speak English here. Question moved from Misc category to Sharp. Paper Jam on tray 2 lift mechanism. .
Error Codes > Sharp > MX7090 > page 1
PrintCopy .info https://printcopy.info > brand=Sharp > model=MX7090 Causes: Scanner expansion PWB (ACU) (ACRE) ROM data error. An error occurs during firmware upgrading for some reasons. Remedy: Perform firmware upgrading again.
Error Codes > Sharp > MXM623N > Code F3-22
PrintCopy .info https://printcopy.info > brand=Sharp > code=F3-22 Code: F3-22; Description: Paper feed tray 2 lift operation trouble; Causes: T2LUD does not turn ON within the specified time. T2LUD sensor trouble. Missing: 7090 ‎' Show results with: 7090
Paper Feed Tray 3 Lift Operation Trouble - Sharp MX ...
ManualsLib https://www.manualslib.com > ... > Service manual Cause: Toner cartridge (CRUM) trouble. PCU PWB trouble. Connector and harness trouble between PCU PWB and toner cartridge. ..
3/19/2025 4:46:48 PM • Sharp Office... • Answered on Mar 19, 2025
Sharp AR-5731 Printer. Please tell me, on this copier Sharp AR-5731, error L8-10
  • Code: L8 10
  • Description:Power abnormality detection trouble. The power status monitoring signal keeps power OFF state after passing the specified time (2sec).
  • Causes: Circuit around the power status monitoring signal (PSSTS) failure.
  • Remedy: Check whether power status monitoring signal (PSSTS) on MCU PWB is OPEN or not. Replace MCU PWB.
https://printcopy.info/?mod=erc&brand=Sharp&model=AR5731&code=L8+10 ..
3/17/2025 7:53:41 PM • Sharp Office... • Answered on Mar 17, 2025
SHARP MX 3115 PHOTOCOPIER. How to clear error code H3-02 please?
Question edited for clarity, add magic word.Question moved from Misc category. Drive to the fuser unit. https://www.copytechnet.com/forum/technical-forums/copier-technical-discussion/sharp/170388-mx-6070v-h3-02-error-code ..
12/25/2024 12:15:32 PM • Sharp Office... • Answered on Dec 25, 2024
2answers
Sharp AR-5618S copier. What is the code to reset toner chip please?
Question edited for clarity, add magic word. Question moved from Misc category. This says; How do I reset my printer toner chip?
  1. Press the tiny reset button located beside the chip and hold for 10 seconds. Depending on the brand and model of the cartridge, you may not need to hold the button for 10 seconds, but it won't harm the cartridge so do it anyway just to be safe.
  2. Done.
Everything else says you just replace the chip with a new one. It is better to buy genuine OEM cartridges for trouble free operation and quality prints. https://www.google.com/search?q=code+to+reset+toner+chip+for+sharp+copier+ar-5618S ..
12/3/2024 10:31:46 AM • Sharp Office... • Answered on Dec 03, 2024
How can I connect my sharp AR-M420u to my desktop or my phone
What OS does your computer have? I have found a site that claims to have the PCL6 drivers for Vista and Windows 7 (32-bit) and earlier versions of Windows. https://www.driveridentifier.com/scan/sharp-ar-m420u/download/1550221446/A13F4E2F524A4FE29DF6E43348CDEF86/LPTENUM%5CSHARPAR-M420U8CB4 . However, several of the drivers are listed as 3rd party and in the .rar format. (You need 7-Zip or a similar program to extract that archive.) If you have a recent version of Windows, the above driver packages won't help. Windows 10 and 11 require manufacturer signed 64-bit drivers. I don't see an AR-M420 listed at https://global.sharp/restricted/print/select.html?view=2& . I tried several regions. It looks like the manufacturer stopped supporting the unit. Unfortunately, this all-in-one printer will not interface with any wireless phone or gadget. (If it has a Fax function, it might let you daisy chain it to a landline wired phone.) I wish that I had better news for you. Cindy Wells
9/2/2024 11:16:38 PM • Sharp Office... • Answered on Sep 02, 2024
2answers
My sharp mx-m354 printing good, but the copy is light on top of the page. I cleaned the scanner but it ain't work. What shall I do?
A common cause of faded or faint printouts from your inkjet printer, is dried ink particles causing a blockage. The printheads on an ink cartridge can be become blocked if the printer is not used for a period of time, so it is recommended to print a few pages each month to maintain the print quality
8/9/2024 3:58:46 AM • Sharp Office... • Answered on Aug 09, 2024
Sharp MX-4071 printer. How do I fix H3-01 error on it please?
Question edited for clarity and add magic word.
Error Codes > Sharp > MXM264FP > Code H3-01
PrintCopy .info https://printcopy.info > brand=Sharp > code=H3-01 Code: H3-01; Description: Fusing section high temperature trouble (TH_US) Sub heater lamp abnormally high temperature software detection trouble . https://www.google.com/search?q=Sharp+MX-4071+printer+H3-01+error ..
8/6/2024 3:41:31 AM • Sharp Office... • Answered on Aug 06, 2024
Sharp AR 5320 Printer. What are the step by step procedures for toner and developer initialization please.
Sharp Ar5316 Ar5320 Service Manual
calameo.com https://www.calameo.com > books ... Toner developer cartridge x1 9K AR-016TD *Life setting by LT 5% document ... not detected when initializing the shifter. Cause CRUM chip abnormality ... ..
7/24/2024 4:58:54 PM • Sharp Office... • Answered on Jul 24, 2024
My Sharp XE-A21S cash register beeps while I am trying to set the date during reprogramming.
Are you using the Programming key. Usually that special key has 'PGM' stamped on it and not kept with the register. help here https://www.google.com/search?q=Sharp+XE-A21S+set+date ..
7/20/2024 4:57:52 PM • Sharp Office... • Answered on Jul 20, 2024
Sharp AR-5127 Digital Laser Copier Printer. Call for service H4-00. How do I clear it please?
Error Codes > Sharp > AR5127 > page 1
PrintCopy .info https://printcopy.info > brand=Sharp > model=AR5127 Code: CE 00; Description: The other communication error has occurred. Causes: Network Cable connection failure; Remedy: 1) Check that the Network Cable is ...
SOLVED: Sharp AR 5127 H4-00 problem
Fixya https://www.fixya.com > support > t24977376-sharp_ar... Aug 19, 2014 - This means that the cartridge's sensor is miscommunicating with the copier memory thus the code U2 -40. You should clean the inner sensor ...
My sharp ar-168s copier is displaying a code H4-00 what ...
JustAnswer https://www.justanswer.com > printers > 3o7pu-sharp-ar... Jun 27, 2010 - Hello this is Charles with Just Answer, This code means the fuser is not heating up properly or the thermistor is not reading a change in ... ..
7/11/2024 5:53:45 AM • Sharp Office... • Answered on Jul 11, 2024
Sharp AR- M207 Multi-Function Copier. How do I return to the copier mode on it please?
A quick way is to disconnect from the mains wall plug for one minute, then press and hold the Power button for 30 seconds. Plug back in. Or the Manuals
AR-M162 ' AR-M207 Operation Manual Suite
Sharp Business USA https://business.sharpusa.com > portals > Manuals PDF Be sure to keep all operation manuals handy for reference including this manual, the "Operation manual (for general information and copier)" and operation ...
AR-207 Operation Manual - Sharp Business USA
Sharp Business USA https://business.sharpusa.com > cop_man_AR-207 PDF Copying is possible when the indicator is on. Press to start copying. CLEAR ALL ( ) key. Clears all selected settings and returns the copier to the initial ...
AR-M207 Operation-Manual Online-Guide GB
Sharp Europe https://docs.aws.sharp.eu > 34_ppc > ARM207_O... PDF Note. • For information on loading paper, replacing toner cartridges, clearing paper misfeeds, handling peripheral devices, and other copier-related ... 35 pages
Sharp AR-M207 Copier print function under Windows 10
Microsoft Community https://answers.microsoft.com > windows > forum > all Mar 11, 2018 - If you log into the copier settings through the Print mode, select the "special functions", then Key Operator PGM. the password is 00000 by ... Issue with Sharp AR M207 on the computer. Sep 13, 2014 Sharp AR M207 will not install on Windows 8. Are there going ... Sep 24, 2013 More results from answers.microsoft.com Missing: return ‎' Show results with: return
AR-M207 Operation-Manual Setup-Guide GB
Sharp Europe https://docs.aws.sharp.eu > 34_ppc > ARM207_O... PDF ... manual (for general information and copier)". • The dual function board ... return to the "Chooser" dialog box. (1) Verify that the machine is selected ...
6/28/2024 5:40:40 PM • Sharp Office... • Answered on Jun 28, 2024
Sharp DM 2010 Laser Printer Logo
4 questions posted
Top Sharp Office Equipment & Supplies Experts
George Mclaughlin
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
copies ck or ch message won 39 t copy
  • Office Equipment & Supplies
