20 Most Recent Jensen UV8 Phase Linear Questions & Answers
How to set time on jensen jcr-425
To set the time on a Jensen JCR-425 clock radio:
  1. Press and hold the "Time Set" button until the display flashes.
  2. Press the "Hour" and "Minute" buttons to adjust the time.
  3. Press "Time Set" again to confirm.
3/10/2024 5:59:32 AM • Jensen Audio... • Answered on Mar 10, 2024
Jensen Compact Disc Music system JMC-500W. Open/Close button not opening the lid
Hi, Please hold down the open/close button instead of just pressing it. Then you can press the lid while this is happening. I think you might already suspect this, but it sounds like the hook that connects to a portion of the lid isn't unhooken during the button press. Friction might be a cause or the hook-movement might not be functioning as smoothly due to other factors. If the issue continues, we might have to consult Jensen on a potential repair/replacement of the item as well.
12/27/2022 1:14:00 AM • Jensen Audio... • Answered on Dec 27, 2022
How do I find the VIN # for my Jensen JVR212T radio?
radio has a serial number your vehicle has a vin ----
8/15/2022 1:59:35 PM • Jensen Audio... • Answered on Aug 15, 2022
I bought berkley jensen siena 3-tiered fountain and there is no pump in the box and no manual
I'd contact the manufacture and tell them there wasn't a pump in the box, they should send you one verses having to purchase it.
6/24/2022 12:50:31 PM • Jensen Audio... • Answered on Jun 24, 2022
Turntable on my Jensen JTA-460 is slow. I have replaced the belt and made sure table was lubricated. No change. Can not find a way to adjust speed of table.
Check the belt is fitted correctly. If it is not it will affect the speed. If the speed is slow on both 45 and 33 rpm, then it could be the motor. Sometimes there are speed presetts at the none shaft end of the motor. If it doesn't look like the motor has any built in electronics in it, then look to the turntable power supply look for faults in that.
6/5/2021 2:32:13 PM • Jensen Audio... • Answered on Jun 05, 2021
Why cant i play mp4 video files on my jensen vm9115 usb?
Probably incompatibility
11/19/2020 12:22:52 AM • Jensen Audio... • Answered on Nov 19, 2020
I need instruction Manual Jensen JCR 280 under the Cabinet
To set stations, press set button on far right then search station then press number station is to be set.
1/15/2020 6:35:06 AM • Jensen Audio... • Answered on Jan 15, 2020
Can someone provide the Specs on 'old' Jensen CS 315 speaker, 3 way floor standing. I have 3 units in mint condition.
Hi Tom- I found this link regarding Jensen CS 315 speaker specs. Click on "See More" for further information. https://picclick.com/JENSEN-CS-315-3-WAY-MONITOR-STEREO-SPEAKERS-8-184010428853.html Hope this helps.
1/9/2020 5:51:07 AM • Jensen Audio... • Answered on Jan 09, 2020
Jensen JCR-315 manual
5/31/2019 2:24:55 AM • Jensen Audio... • Answered on May 31, 2019
2answers
I have a Jensen QX80 Subwoofer which has stopped working properly. When I power it up, it turns on and makes a buzzing noise, I could smell a burnt electrical smell when it first occurred. Any advice?
Bill, Sorry that I have to be so general in answering this question. If there is a burnt smell associated with the occurrence of the problem, then that would point to a fault most likely in the audio output circuit. If the unit blows a fuse, then I tend to think that it is in the power supply of the internal amplifier. Either way, service is needed for the unit. It is best to disconnect the unit from your sound system and try to find someone qualified for this repair.
3/29/2019 10:57:27 PM • Jensen Audio... • Answered on Mar 29, 2019
Can I input a Satelite radio receiver into my Jensen JSM 96; ..................If so how?
Does your Jensen have the AUX inputs on the back or front? You would need to find a Satelite radio with the Outputs that will plug into the AUX Inputs. Some radios have a special input connections for Satelite radios, so check the Manual.
1/25/2019 4:15:02 PM • Jensen Audio... • Answered on Jan 25, 2019
Jensen UV8 Phase Linear Logo
13 questions posted
Top Jensen Audio Players & Recorders Experts
Ngoro
john h
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Jensen Audio Players & Recorders
Most Popular Question
jensen cassette player recorder doing
  • Audio Players & Recorders
