20 Most Recent
Interface For Ford® Questions & Answers
Car alarm just goes off randomly
Check the battery in the vehicle and the battery in the actual keyfob itself. Sometimes when one of these are low the alarm will randomly sound. The random alarm sounding is typically an indicator of a low battery somewhere. What is the year make and model of the vehicle? Some, like bmw's, have sensors under the hood, on doors and windows that get stuck and randomly sound the alarm. Please Advise
Vr3 200watt amplifier red light problems
Why does the Power / Protect LED switch between green & red?
Suspect the power and ground connections, insufficient wire size to carry the current demand,
or an improper impedance load (especially if bridging two channels into one.
Why does the Power / Protect LED stay red?
This typically indicates that one or more of the MOSFET output transistors has shorted
This is straight out of the user manual.
How to set time and alarm in KADIO KD-3810N
Insert Batteries: First, insert 2 AA batteries into the back of the clock.
Access Time Setting Mode:
Press and hold the Mode button for 5-10 seconds until the clock enters the setting mode.
Adjust Time:
Once in the setting mode, use the Up and Down buttons to change the time, month, and date.
Press the Mode button to cycle through the different settings.
Set Hour and Minute:
When you reach the time setting, adjust the hour and minute using the Up and Down buttons.
Press the Mode button again to move to the next setting (e.g., month, date).
Exit Setting Mode:
After setting the time, press the Mode button to exit the setting mode.
Panasonic SE-b80 stereo power amplifier. Where can I get a schematic diagram?
Besides the 3-wire cable that has Left-Ground-Right inputs, there is a cable connected to the transformer. That can be cut, was used to bring power to the HiFi set.The other wire bundle with 7 wires, (J107) is the control. You can cut and use the 2 wires on the right of the connector as the on/off contact. Connecting these 2 wires makes the amp turn on.
