20 Most Recent White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit Questions & Answers
2answers
How do I program my
Download a PDF version of the Operating Manual HERE. ___ *Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera "The problem can always be solved with the materials in the room." -My college Physics Lab Professor
2/9/2021 4:44:58 PM • White Rodgers... • Answered on Feb 09, 2021
1F78 thermostat change from F to C
yes to cut the wire named W904 at the middle.
9/17/2020 3:47:22 PM • White Rodgers... • Answered on Sep 17, 2020
I have a 1F81-51 White-Rodgers thermostat that
I had the exact same problem. Even pressing the Hold button does not really help, because once it resets - the Hold temperature also changes to the default.
I fixed this by replacing the 470 micro-Farad / 10v capacitor in the unit (it's the grey-colored capacitor). To access the back of the circuit board, you will need to break 2 plastic rivets holding the front of the unit to the base.
After replacing the capacitor I've not had any resets for the past 3 days (it used to reset itself every couple of hours).
Hope this helps.
Noel
3/20/2020 10:38:03 PM • White Rodgers... • Answered on Mar 20, 2020
2answers
I have just changed the batteries on the
Look for a tiny reset button in the area where you replaced the batteries. Very tiny button. Might need a pen point to press it.
10/10/2018 5:59:35 PM • White Rodgers... • Answered on Oct 10, 2018
2answers
My white-rogers 1F81-261 model thermostat keeps
MANUAL OPERATION
• HOLD TEMPERATURE — With the SYSTEM switch set to
HEAT or COOL, momentarily press HOLD button. HOLD
will be displayed. Use UP or DOWN to adjust the temperature.
The thermostat will hold the room temperature at the
selected setting until you press RUN button to return to
program operation.
This is on page 6 of the manual
Link: Installation Instruction
1/1/2018 12:12:13 AM • White Rodgers... • Answered on Jan 01, 2018
My thermostat resets itself
BE absolutely sure the batteries are good. This is what usually causes this symptom, even it the 'battery indicator' isn't asking for a new battery. It happens a lot on systems that are being turned off with the breaker, safety or service switch; DON'T do that. When you put a set of brand new alkaline or lithium batteries, with the thermostat off the wall, leave NO batteries in it for about an hour. Be sure that the power is on 24/7 to the system. To stop the system from running, always use the "Heat--Off--Cool" switch.
11/2/2017 6:49:22 PM • White Rodgers... • Answered on Nov 02, 2017
My old thermostat, Honeywell Pro
may be able to jumper them as the are the same. if still confused do a search on that thermostat wiring diagram and see. or try this site might help. Thermostat Wiring Explained http://www.electrical-online.com/thermostat-wiring-explained/ good luck
10/24/2017 2:01:07 AM • White Rodgers... • Answered on Oct 24, 2017
4answers
I have a White Rodgers thermostat series 1F78-151
you need a replacement obviously. this one is cheapest I have found. take a look: White Rodgers Programmable Thermostat 1F78 151. I hope this was helpful. cheers
2/17/2016 2:44:58 AM • White Rodgers... • Answered on Feb 17, 2016
Filter shows up in window. I just put a new one in
Press and hold the filter button for 15-20 seconds to clear filter notification. Some programmable models allow you to change the interval of the filter notice. This is only a filter check reminder for a set period of time, it does not indicate the filter condition at all, just to remind you to look at the filter to see if it needs replacement or cleaning.
5/28/2015 2:28:52 PM • White Rodgers... • Answered on May 28, 2015
0answers
White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit Logo
300 questions posted
Top White Rodgers Home Security Experts
john h
Arnie Burke
Arnie Burke
Are you a White Rodgers Home Security Expert? Answer questions, earn points and help others
View Most Popular
  • White Rodgers Home Security
Most Popular Question
white rodgers thermostat series 1f78 151
  • Home Security
