20 Most Recent
Pinnacle Inertia Baitcast Reel Questions & Answers
Bird nesting
common problem especially with new users who are used to fixed spool casting, when casting with a multiplier you should keep your thumb over the drum so you can slow down the drum as your cast slows to fall in the water, if you had a drag washer you wouldnt be able to cast, you will get the hang of it with practice, but even with 30 odd years of use i still ocaisionaly get a nest.
LINE GUIDE WANT MOVE BACK & FORTH
There is a diamond bar (my name for it) that the guide slides back and forth on. There are groves cut in it. Make sure that nothing is stuck in any of the grooves. Clean them out thoroughly and relube the bar. Inside the guide there is a post that rides in those groves. If doing the above suggestion doesn't cure the problem the guide may need to be replaced. Currently their website is not completed yet and there isn't access to the parts diagrams. This is the address. You can check there later and see if the site is completed.
http://www.pinnaclefishing.com/shop/t-parts-diagram.aspx
What is the best fishing rod and reel brand?
St. Croix, Shimano, Shakespeare are popular fishing rod brands and you can choose from these brand without any hesitation. Daiwa, Abu Garcia, Shimano are popular fishing reel brands available in the market. All the product from these brand is durable and high quality and you can purchase from these brands. I have found a pair of an article about the best fishing rods and reels that you can check. Here is the articles:
Best Baitcasting Reels brand
11/30/2022 3:36:23 PM •
Fishing
Answered
on Nov 30, 2022
How do I choose the best fishing reel size for my needs?
Small Spin Reels:
Spinning Reel Size: (1000 or 10)
- Suggested mono: 1-2kg (2-4lb)
- Suggested Braid: 4-8lb
- Common Applications (Guide only): Small fishing reel mostly suited for light fishing in lakes, rivers, bays, harbours etc.
- Popular for fish type (most common species): Bream, Trout, Whiting.
Choosing a fishing rod to go with this size reel: - As the 1000 or 10 sized spinning reel is quite small, a rod you would typically pair this reel to is one with a length of around 6-7 foot that has a fishing line rating of anywhere between 1-4Kg.
Spinning Reel Size: (2000 or 20)
- Suggested mono: 2kg-3kg (4-6lb)
- Suggested Braid: 5-10lb
- Popular for fish type (most common species): Bream, Trout, Whiting, Bass, Flathead, Perch, Luderick.
Choosing a fishing rod to go with this size reel: A 2000 or 20 sized reel being a quite small reel ideally will suit a fishing rod between 6ft - 7ft 6 inches in length that has a line class rating somewhere between 2-5Kg.
Medium Size Spin Reels:
Spinning Reel Size: (4000 or 40)
- Suggested mono: 4kg-6kg (8-12lb)
- Suggested Braid: 8-20lb
- Common Applications (Guide only): Medium fishing reel mostly suited to lakes, rivers, bays, harbours, light offshore boat fishing etc.
- Popular for fish type (most common species): Snapper, Morwong, Tailor, Mangrove Jack, Cod, Bone Fish, Barramundi, Mulloway, Drummer.
Choosing a fishing rod to go with this size reel: A 4000 or 40 reel is where you start to gain a little size so this sized reel will generally suit medium action classes of rods in the 6ft-7ft (barra/snapper style rod) with a line class of around 4Kg-10Kg or in an 8ft-10ft (light surf) rod with a light line class rating of around 3-5Kg. Remember this is a guide only to suggest common applications so by all means you can use this reel for several other applications as well.
11/16/2022 5:20:40 PM •
Fishing
Answered
on Nov 16, 2022
How to buy a fishing reel
Depends on what type of fishing your doing. Out of the two the bait caster is the more challenging to do because you control the line going out. That is good for fishing banks, logged areas, spinner bait. If you just want to cast with bobber go with open or closed reel. Hope that helps.
11/11/2022 1:45:31 PM •
Fishing
Answered
on Nov 11, 2022
