Questions & Answers for: 1999 windstar starting - Page 2
1999 Ford Windstar Van, speedometer not working My 1999 Ford Windstart Vans speedometer works when I first start it then stops when it gets warmed up.... sound like bad connection at vechicle speed ...
redid firing order,now car dont start.1999 ford windstar Did you try to unplug your battery cable to reset PCM
...1999 Ford Windstar and during the winter the van starts all the time. When spring and summer hits the van will start but when I shut it off it will take about three hours before I can start it again. ...
...a 1999 ford windstar but it wount start the engine will not turn is it getting spark , if not then check the fuel system then the starter .it might even be something as simple as your starter
the antitheft system on my 1999 windstar has engaged and the car won't start what can I do? Most antitheft systems are reset by using the key in the driver's door, and turning to the left and back.
Question about 1999 Windstar
...1999 ford windstar how do i reset the alarm to start it every time you turn the ignition key to on the system is reset, so if the security light is flashing with a no start u have a hard fault in the ...
1999 ford windstar won't start due to anti theft malfunction stranded with kids HELP sometimes just by turning the key in driver side door will disable the sysytem.
...windstar 1999 just died all the lights were flickering and then it died i got it started back up then it slowly died again now its rear lights are on and the dash light to whats the problem do you ...
...1999 ford windstar and it wont start the computer exchange said to check if the theft light flashes when i try to start the van and yes it does how do i reset the chip in the key to get the van ...
1999 ford windstar not starting just cranks Car ran fine yesterday, got up this morning, would not start just cranks, but i can hear the fuel pump engaging, what might the problem be. Thank you does ...
Top Cars & Trucks Experts
john h
Are you a Cars & Trucks Expert? Answer questions, earn points and help others
