transmission problems My 1995 windstar is just fine when you start it, then it seems as if you let it heat up (about 5 or 6 blocks) the transmission gears start slipping and dont want to stay in gear,
...1999 Ford Windstar, It has been running great for the last 94K miles. Today I went to start, there was a click and all power shut off. The power does not return on it's own. While checking all the ...
...1999 Ford Windstar will not start. Drove it to a friends house just fine and went to leave and it wouldnt start. Havent been having any problems with it. Charged the battery, holds the charge. Will ...
99 Ford Windstar My ford windstar have alternator problem, which is being fixed today. Currently, it has 142K miles on it. I am wondering how long this van can last since it has start giving me BIG ...
1999 Ford Windstar, 3.8 Liter engine. When attempting to start, there is a clunk, but the engine does not move at all. The dash lights dim completely. I tried jumping the battery off another car, ...
I have a 99 windstar that won't start the battery alternator and starter all work but the anti theft thing won't let it turn over what do I do call the dealer or a auto locksmith but do try ...
...windstar 99 are always going crazy Sounds Like the Main Dashboard is Goin try to find One At Local Wreckers to replace it cause it will die soon then your Done No Starting so will have to go to The ...
1999 ford windstar The CKP sensor is actually the Crankshaft Position Sensor. It is responsible for ignition timing. When each piston reaches the position for firing, the CKP sensor informs the engine
oil is leaking in the front of my 99 Windstar when I started upy And the question ! Where does it leak ? If you do not work on vehicles yourself You get the idea Has to be repaired, if your keeping it
...1999 ford windstar Janelle, I don't want to give you the wrong information here so I'm going to first ask why you want to do this? Is it causing other issues? I may be able to help with the other ...
