Questions & Answers for: 1994 4runner - Page 9
Question about 1994 4Runner
torsion bars Do the torsion bars on the toyota 4 runners get week and sag Hello, the torsion bars on toyotas especially the 4 wheel drives can sag over time and I have seen them break also. Matter of ...
emissions and vacum hose routing for a 94 toyota 4runner 3.0 i bought a 94 toyota 4 runner that had no engine .I bought a new engine to go in it but I need a diagram of emissions and vacum hose ...
why when my 94 4runner gets hot it will not start why when my 94 4runner gets hot it takes a min to start back up i let sit for a few min and then will start You most likely have a fuel problem but ...
4runner water leak under motor I just bought it and I'm pretty sure I can tackle the problem if it's not too serious, I'm guessing it's the water pump failure and nothing else serious. Anyone has any ...
were is the thermastate located on 1994 30lt surf cheers It's located down at the bottom of the engine if it's the three liter, you will have to remove belts and timing cover to get to it.
1994 toyota4runner won hardly crank.like not gettin gas Did you check the fuel punp fuse and relay located in the box -driverside under the hood?
1994 4runner: Is there a way to get the Check Engine Light code without the scanner tool? Does anyone know where to find a list of trouble codes for the '94 4runner? there should be a connector under ...
94 toyota 4runner no start, possible fuel relay, removed left kick panel unable to identify which relay bad try looking in black fuse box under the hood, usually on drivers side. lift cover off and ...
1994 4runner swapped engine 3.0 to a 1990 3.0 everything hooked up good. Spits fuel out the intake. 1992 is a 2wd and 1990 is a 4wd. Is it ECU issue? dont think so ?have you used the old 94 manifolds ...
...1994 4runner and it keeps blowing fuse for gauges when I put it in reverse Sounds like a wire being shorted out in the shift console. I can't remember how to take out the console, but it's usually as ...
Top Cars & Trucks Experts
john h
Are you a Cars & Trucks Expert? Answer questions, earn points and help others
