Questions & Answers for: 1994 4runner - Page 6
Question about 1994 4Runner
como poner un estereo i want to know how i can put the stereo on my car toyota 4runner 94 estereo original? o uno comprado aftermarket? eso significa un radio o estereo no origina
rocker switch for 94 4runner My interior rocker switch for the rear window in my 4Runner will work to make the window go up but not down, and the key always works. How do I take the rocker switch out?
1994 3.0 EFI SR5 4Runner overheating Replaced radiator, hoses and the thermostat still overheats and has no water loss check the engine timing !
...1994 Toyota 4Runner with a V6 and the check engine light came on i jumped the terminals and code 14 and 26 came up. what does the codes mean? These are the codes and possible causes taken from ...
toyota 4runner will not start just replaced head gaskets and timing belt by the book any suggestions DID YOU BLEED THE LIFTERS
try to remove alternater from my 94 4runner any tips What type of motor do you have so I can post the diagrams to show what you can do to make it easier.... Do you have: 22r 22r-E 3vz-E 3f-E
need a diagram for a engine v6 94 4runner 4wheeldrive im replacing waterpump on it type in your browser http://www.ehow.com/how_4867016_replace-water-pump-runner.html girls can do this too
power steering pump for 94 4runner not leaking but loosing fluid somewhere, any ideas suspect the rack and the fluid is filling up behind the rubber steering gaitors
1994 toyota 4runner v6 valve adjustment? i hear it requiers shims to adjust,where are shims avalibile,what tools do i need and whats the procedure and anay else i need to know Shims are ONLY available
why does my toyota 4runner steering wheel lock while driving Why does my 94 Toyota 4runner steering wheel locks while driving.we pulled out the keyed ignition and started with pliers and still locks ...
Top Cars & Trucks Experts
john h
Are you a Cars & Trucks Expert? Answer questions, earn points and help others
