SOURCE: what type of fuel line removal tool 4 99 chev malibu?
It should use the white nylon release tools. I think there are 5-6 in the set,
SOURCE: the rivet tool dose not grip the pin....I never used this tool
The pin fits into the end of the gun into a three jaw chuck (like three fingers with small horizontal grooves on the inner surface) which grabs the pin. This pulls up on the pin while the small ball at the end of rivet begins to compress the end of the rivet. There is either a spent pin lodged inside the end of the gun or the grooves are worn down making a good grip impossible. Clear the pin from the tip by raising handle to full open position and try to dislodge the pin with a wire or nail. You can also take the handle assembly apart and clear the pin and or inspect the internal grooves.
SOURCE: have a stanley tre550 and need to know how to use
The staples are NOT loaded on top of the pull out shaft; they are inserted directly into the slot that opens when you pull the shaft out. If the nose of the tool is not placed firmly against a surface, it will not fire. Go to Stanley’s website’s knowledge base and type in the model number, and you can get a PDF of directions. http://www.stanleytools.com/default.asp?TYPE=STATICLEFT&PAGE=Support.htm&LEFT=left_support.htm Below is the graphic from their pdf. Here is a step by step: Unplug the tool. Squeeze the end of the shaft at the rear bottom of the tool and pull out the shaft. Flip the tool over on it’s back. Insert the staples, (points up) and then slide the shaft back in. Plug it in, press the on button (under the the power cord in the back). Press the nose squarely against the material and press the trigger.
SOURCE: I require instructions / manual for Super Works
Try www.manualnguide.com they have a huge selection of manuals for tools and you can download it for free its great hope this works for you
SOURCE: Stanley MR99 Riveter I dissasembled to release a
How do I dismantle the spiral from the outer casing of a yankee screwdriver
