Locks & Locksmithing Logo
Posted on Jul 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to reprogram the keypad - Weiser Lock Locks & Locksmithing
Anonymous
Level 3:
President:
  • Master 228 Answers
  • Posted on Jul 27, 2011
Anonymous
Master
Level 3:
President:
Answers
228
Questions
0
Helped
134950
Points
5507
First, push the program button on the power board once. Enter the four to eight
digit code by pressing the numbers on the outer touch pad. Press the lock button on the
lock button on the touch pad to set the code. You will hear a two second long beep when
your code is accepted. If the unit does not beep, too much time has elapsed between pressing
the program button and entering the code. Repeat the programming sequence. Enter your number
to check that it works.
How do i change the code on my schlage BE365. I want to delete my current one and add a new one
You confused me about which model-the FE575 or BE365 lock that you are dealing with, but that's no problem. The information for either can be found on the same page.
This link will take you to the page you need, to get started:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Reprogramming FE575:
Scroll down to this heading on that page:
Electronic Security-Keypad Entry Flexlock...
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number that you need to reprogram the lock. This installation video (fourth item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery!
The ninth item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that program code that you found on the backside of the keypad.
Reprogramming BE 365:
Electronic Security-Keypad Deadbolt BE365
This installation video (second item down) will be useful to allow you to disassemble it and view the sticker.
The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that program code that you found on the backside of the keypad.
Nedd to reprogram security code
Then scroll down to this heading on that page:
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number that you need to reprogram the lock. This installation video (second item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery!
The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that programming code that you found on the backside of the keypad.
2helpful
Do I have to reprogram my lock after changing the battery?
Does the Schlage Keypad Lock or Keypad Deadbolt need to be reprogrammed after changing the battery? The Schlage Keypad Lock and Keypad Deadbolt does not need to be reprogrammed after replacing the battery. All settings are retained in the memory of the lock, including valid user codes and the programming code.
I'm including a link to the pdf file of the complete installation and programming instructions:
http://consumer.schlage.com/Project%20Documents/P515-859.pdf
You may also find more useful information on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx#1
We have a Model 1245R Lift_master Professional Line 1/3 H.P. Security+ garage opener. We need to reprogram our wireless keypad but the instructions refer to an ENTER button when our keypad has NO ENTER...
If your keypad doesn't have the enter button it is an earlier model and will not work with what you have now. You will need to call your Liftmaster dealer to get the latest model.
Garage door opener keypad stopped working. cannot reprogram it.
It could just be you need to replace the battery.
The warning light might be a "battery low" warning - advising you to replace it!
If it stops flashing, the battery has died altogether.
Keypad garage door doesnt work all the time
MAKE SURE YOUR BATTERY CONNECTIONS ARE CLEAN AND TIGHT.
IF YOU HAVE REPLACED THE BATTERY AND REPROGRAMED THE KEYPAD TO THE OPENER YOU PROBABLY HAVE A BAD KEYPAD AND WILL NEED TO REPLACE IT
8helpful
Reprogram key pad for garage door opener
To program the keypad, you will have to press the LEARN button on the back of the garage door opener console and when it begins to flash, enter a new 4 digit code on your keypad and press enter. You should hear a click and see the lights on the opener flash.
Top Weiser Lock Locks & Locksmithing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
