Microwave Ovens Logo
Posted on Jul 27, 2011
I have a Sharp Carousel Microwave Model R-305KS, countertop, manufactured Apr 2009 that isn't heating. It makes a louder than normal sound and the carousel is working. Have any idea what may be wrong?
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jun 23, 2008
SOURCE: R-4H84 Sharp Carousel II microwave oven stoped working
A microwave can be dead for many reasons.
The fuse is normally located on the floor of the chassis behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
informatica
Greg Cann
  • 1114 Answers
  • Posted on Aug 07, 2008
SOURCE: I need Aan instruction manual
Hi - You can download the manual from the link underlined in blue below:
R-305KS
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Jerry Naidoo
  • 152 Answers
  • Posted on May 13, 2009
SOURCE: sharp carousel r-508ak - does not heat up the food
You probably have a defective magnetron or blown fuse supply power to magnetron.
Anonymous
  • 456 Answers
  • Posted on Aug 16, 2009
SOURCE: Looking for instruction manual Sharp \carousel
if you google the model number and the brand you should be listed with a series of sites that supply manuals, service manuals, etc.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Dec 27, 2009
SOURCE: sharp carousel 1993 r1420b, how to remove from
One of these installation manuals may be close enough to yours to help you: manual 1 | manual 2 | manual 3
Testimonial: "thanks for your help, real fast return."
Top Sharp Microwave Ovens Experts
woodzowl307
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
