Combi Centre DX - Mango Logo
Posted on Jul 26, 2011
We have a problem with the hot water, Baxi Luna combination boiler. Normally when the hot water runs out, we get an error message, but this time there is no error message and the water turns cold after only a few minutes. Any advice on what we should look for? We are not experienced with this type of boiler.
4 Related Answers
Anonymous
  • 16 Answers
  • Posted on Aug 17, 2009
SOURCE: Baxi/Potterton wall hung fan assisted combi boiler
does the boiler come on when the hot water tap is run if not change the hot water flow switch or the diaphram in the hot water flow valve it may be split
Anonymous
  • 248 Answers
  • Posted on Nov 06, 2009
SOURCE: Manual for Baxi Boiler
any merchant will get one mailed out to you
Anonymous
  • Posted on Jan 14, 2010
SOURCE: water gets hot then turns cold and runs cold then hot again
Secondary heat exchanger is blocked on sealed system side.
Remove and de-scale heat exchanger or fit new one.
Anonymous
  • 36 Answers
  • Posted on Jan 31, 2010
SOURCE: boiler is a baxi control for heating is honeywell.
this will be your diaphram inside your divertor valve.
the one that looks like a spaceship.
it will e split.
Top Combi Baby Gear Experts
Paul Carew
Stephen
Stephen
Level 1 Expert
Anonymous
Level 1 Expert
Are you a Combi Baby Gear Expert? Answer questions, earn points and help others
