Have GE JGSP48, getting error code F7 d9 flashes on until i press clear button, then the clock comes back on. about 3 to 4 minutes later it starts beeping again and the F7 comes back on. none of the other buttons will work. the only button that works is the clear/off button.
Clock works ok. have opened panel and cleaned it.
How do I get the rest of the buttons to work?
SOURCE: Kenmore oven clock control installation instructions
powerman's solution worked great. It took me about 10 minutes. Just needed a sheet of paper, scissors and a philips screwdriver!
SOURCE: Jenn Air Oven Model # SVE47600B Error Code F7
I have a jenn air SVE47600F.It just started beeping and giving a code 7.None of the controls work when it brings the code up,but controls work fine when code is not there. We have to turn the breaker off to reset it.Sometimes when we have been gone all day we'll come home and the range will be beeping and flashing a code 7
SOURCE: Jenn Air F7 error msg with incessant beeping
F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button
SOURCE: Display shows error code "F1"
F1
Failed Thermistor Control
Replace Electronic Range Control (ERC)
Good Luck and Please Rate Fixya!
SOURCE: F7 appears on GE double oven JT950SA
f7 is a stuck keypad or overlay all you can do is replace it
Same problem here - worked fine then we had a power outage. When the power came back on the stove developed the problem.
