Posted on Aug 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Won't print - Lexmark Office Equipment & Supplies
  • mommygod Aug 29, 2008
    checked all of the above solution but still doesn't print.An alert comes up and says error on script page.
Ekse
Level 3:
  • Lexmark Master 13,435 Answers
  • Posted on Aug 29, 2008
Ekse
Lexmark Master
Level 3:
Answers
13435
Questions
82
Helped
4168389
Points
38024
Hey,
-Drivers and software need to be installed on the pc
-Printer needs to be set as the default printer
-Printer needs to be turned on.
-Printer needs to be connected into the pc.
  • Ekse Aug 29, 2008
    Try to print from the toolbar menu File -> print
  • Ekse Aug 29, 2008
    There*
Casio hr100tm won't print, shows E, won't feed paper. It calculates in On mode only.
mi sumadora, de repente se queda en E y no me deja seguir sumando cantidades que solucion tiene esto
My office jet G85 won't print. No error messages appear,it has a new color cartridge,it copies, but won't print from my computer.
If it copies ok, then the issue is either the way it is cabled to computer or the print driver software settings on pc.... How is it connected via USB? Check port and correct driver is in windows/control panel/printers. Reinstall.
The machine won't print. It won't feed paper, The
Your machine needs to be serviced.
replace the cartridge with the original one.
it can not print if one cartridge is missing or not original.
Printer won't print. I went to printer and it says there are 9 items to br pringted in queue but they won't print Printer says it is ready
Good Day Nanawhit!
That happens all the times when first print job encounter a problem and stops printing and it was followed by series of print jobs. Some reasons for stop printing could be a printer out of paper and printer not set as default printer.
The best way to fix it is to cancel all pending jobs. When print jobs window is cleared off pending print jobs, restart your PC and your printer. Then go to your printer and make sure it is the default printer.
After that try printing a test page. Once a test page is successful, you can now print as many as you want.
2answers
My HP deskjet 2050 all-in-one printer only shoots out blank paper and won't print. It used to say there was no paper in it, which there was. It scans & prints just fine - just won't print...
Any error messages on the printer digital screen or the desktop? I take it the "The ink is fine" means that there is ink in the cartridges!
Try a test print via the Control Panel> Printers and Faxes> properties > Print test page.
Printing problem
how can we print a booklet on this printer
Won,t print
are all the drivers installed correctly? when you try printing off microsoft word (ctrl +p) try viewing the properties
good luck
Jayce
My HP Deskjet 400 won`t properly print a straight vertical line
check the print head belt.......belt that moves the cartridge from left to rite
check to see if all the teething grooves on the belt is intact...and that its all there..if this belt slips a teeth it wont print in a straight line....
4helpful
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
jdthefixer
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
