Computers & Internet Logo
Posted on Jul 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to convert a binary to text - Computers & Internet
Anonymous
Level 3:
  • Master 496 Answers
  • Posted on Jul 22, 2011
Anonymous
Master
Level 3:
Answers
496
Questions
0
Helped
113862
Points
1447
You can use his simple online tool to convert from binary to text and vice versa.
http://www.convertbinary.com/
Anonymous
Level 1:
New Friend:
  • Contributor 16 Answers
Anonymous
Contributor
Level 1:
New Friend:
Answers
16
Questions
0
Helped
2577
Points
47
Letters can be converted into decimal number using ASCII table. Every Character has it own equivalent number. Once converted into decimal (base 10), I could be easily converted into binary (base 2)
You could also use applications or web based applications such as ASCII to binary converter to help you convert it.
How to write a program to translate english text to binary string and write a program to do inverse 27 = . , 28 = , 29= ? 30 = . 31=
to convert from text to binary, you would do something along the following lines..
1. have the user enter a string.
2. loop through the string (for each char in stringEntered..)
3. convert the character to binary using the methods provided to you by your language of choice
For the reverse (binary to text):
you must take 8 bits of data (which would be a single character), and convert it to text using the methods provided by your language of choice..
here's some links that might be of interest to you.
Visual FoxPro VFP CTOBIN and BINTOC Functions Equivalent In Net The Most Accurate and Reliable Source Code Converters
1helpful
2answers
Convert to binary to a decimal 111000
To convert from binary to decimal, we have to line up the numbers with the binary columns.
1 1 1 0 0 0
2^5 2^4 2^3 2^2 2^1 2^0
32 16 8 4 2 1
32 + 16 + 8 + 0 + 0+ 0 = 56
Good luck.
Paul
2answers
How to convert octal numbers into binary numbers
Each octal digit represents three binary digits. Simply convert each octal digit to three binary digits and string them together.
0o = 000b
1o = 001b
2o = 010b
3o = 011b
4o = 100b
5o = 101b
6o = 110b
7o = 111b
As an example, to convert 351o to binary:
3o is 011b
5o is 101b
1o is 001b
so 351o is 011101001b
1helpful
Convert hexadecimal to binary
Press 0 ALPHA [H] 0 1 0 0 1 1 1 0 MODE F2, scroll down to the "Base" line, press right-arrow, select "BIN" then press ENTER ENTER ENTER.
As a note, 01001110 looks suspiciously like a binary number.
1helpful
How to convert binary with point to decimal
1) Look at the following numbers before trying to convert binary to decimal. Each of them represent the value in a binary number from left to right.
128-64-32-16-8-4-2-1
2) Look at your binary number, for this example lets use 10010010. For each one add the corresponding number from step 1, the number you come out with is the conversion.
So: 10010010 -> 128+16+2 -> 146
10010010 = 146
2helpful
How do you convert decimal numbers into binary?
Press MODE 4 to enter the BASE-N mode. Type in the decimal number, then press BIN to convert to binary. Press DEC to switch back to decimal for the next conversion.
You're limited to numbers in the range [-32768...32767] in binary. You can extend the range if you convert to octal or hexadecimal and then mentally convert each digit to three or four bits.
1helpful
How do I convert from decimal to binary?
change your mode to binary , then enter your decimal no in dec link and then press bin link you can get the binary equivalent
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
