SOURCE: Igniter stays lit entire time oven is on Blodgett dfg 100-1
I have seen this happen when a hole develops near where the ignitor is mounted. The excess gass overheats the ignitor and burns it up. What I do in a case like that is slide a c clamp over the burner and cover the hole.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: CANT FIND PART FOR COMMERCIAL PIZZA OVEN
contact first choice with mod no and ser no and they will source your part.first choice is in staffordshire,catering suppliers.
SOURCE: Blodgett Oven won't light
you are improving the voltage across the flame sensor . it probably is just short of being in range, failure to meet the proper micro amps the sensor produces will cause lock out and no ignition. sometimes you can simply adjust the sensor to hit flame better and it will work much better...
SOURCE: need to change over blodgett
No keep the same spring but change the orifice and adjust the air mixture to get a clean burn
