The error code E41 means the control board is detecting an open door switch. It might be due to a broken wire harness, broken door lock/switch assembly, or in worst cases a faulty control board.
Unplug the machine or disconnect power. Open the washer door then look for the retaining hoop securing
the door seal around the lip of the door opening. Stretch the spring of the retaining hoop then remove it.
Carefully peel off the part of the door seal from the lip of the door opening near the
door lock/switch assembly. Remove enough of the door seal to gain
access to the door lock and switch assembly.
Remove the screws securing the door lock/switch assembly to the front panel. Once the
screws are removed, lift the door lock and switch assembly then pull it
away from the front panel.
Take the door lock/switch assembly out of the front panel then disconnect the door switch harness then short circuit the terminals by putting a jumper wire between them.
Put the door lock/switch assembly back into position in the front panel then secure it with the securing screws previously removed. Properly put the eased part
of the door seal back over the lip of the door opening then secure it
with the retaining hoop. Reconnect power and run a test cycle. Replace the door lock and switch assembly
(part #131763202) to address the problem if the washer works fine with
the door switch bypassed. If not, replace the control board.
DTC - 41 MEM- CAL error
DTC - 41 Cam sensor sinal error
DTC - 58 Trans fluid temp sensor circuit error (low voltage)
DTC - 58 VATS System error
I hope this is helpful
