Download this Driver and installed to youre PC: http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=pv-42541-1&cc=us&dlc=en&lc=en&os=228&product=3245025&sw_lang=
Hi felmwakariu,
I see you need drivers but it is not anywhere found in the Website, what version Windows are you using?
If the LAN driver is not present then possible you can just install the CHIPSET Drivers then it should work right, but I checked I do not see the CHIPSET Driver on the site as well.
LAN Drivers are Common just depends on what motherboard you have.
here is a Link for All LAN Drivers you can try one by one till you fin one that is compatible.
http://drivers.softpedia.com/downloadTag/REALTEK+LAN+Driver
Most motherboards have integrated LAN connector(s) on board.
Get access to the system BIOS and make sure that option
is enabled. Boot up Windows and take a look at Control Panel>
System>Hardware>Device Manager. If it is present, then it's
only a matter of providing a proper Driver for it.
Your lan will be disabled from bios
restart computer
press f10
bios will appeares
go to lan setting and enable it
now save settings
and restart the computers run windows
now your lan will appeares
