Kichler PLUG-IN ACCESSORIES - DIGITAL TIMER - 15558-WH - White Logo
Posted on Jul 13, 2011
How do I reprogram the timer - Kichler PLUG-IN ACCESSORIES - DIGITAL TIMER - 15558-WH - White
A
Anonymous
There are many versions of the Kitchler timer.
Some use AA battery, some have rechargeable battery, some have display on upper part and some with display on lower part. Buttons are same on all versions.
Open following links for resources and instructions that may or may not apply to your specific product.
http://waterheatertimer.org/pdf/Kitchler-15558WH-timer.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
I misplaced my instructions for my timer and need to re-set it after a power outage. Can you please send me the instructions? Thanks.
Question posted under Intermatic ST01C, but Timer is not 100% identified since ST01C is battery powered, and should not lose programming or stop working with ordinary power outage.
Most digital timers have a battery or capacitor back-up for power outage.
Add a comment with description of timer buttons, or open link below to see most brands of in-wall timer.
Open following link for to identify Intermatic ST01C and Ei600 and download instructions:
http://waterheatertimer.org/ST01C-program.html#battery
ST01C timer has a battery backup. Power outage will NOT cause battery-powered display to fail, but power outage and power surge can cause any electronic timer to fail.
So either the battery went dead, or power surge ruined timer, or you don't have ST01C timer.
If ST01c display is not showing, then replace battery and then reprogram current time -or- manually re-set timer and then reprogram timer.
We've lost the instruction manual for our light switch timer so don't know how to reprogram it. Directions, please!! We've just replaced the battery.What buttons do we press in what order to...
Question posted under Intermatic timer:
Open following link to identify timer and download possible manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
IF Intermatic timer stopped working because battery failed, then all that's needed is to reprogram current time, because the original timer programs you set are stored inside timer forever until timer is manually reset using reset button.
If you have Intermatic ST01C timer, then open following page for ez instructions:
If you need help programming specific timer, then get as far along in manual as possible, and then add a comment.
If you have different brand timer, than each brand has link that shows on Intermatic page.
Sunset sunrise doesn't seem to work anymore
Timer is not identified.
If digital timer does not function as before, try resetting timer and then re-program.
If timer has battery, then change battery and reset timer.
If reset does not restore functionality, then timer has gone bad. Most in-wall timers have 1 year limited warranty.
Below are common 7-day timers, but there are many different brands:
You posted under Woods 7-day timer: except Woods timer does not astronomic dawn dusk function. Woods 7-day is same as Tork 7-day and GE 7-day, and they do not have astronomic function.
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
Reset button is small round button.
Push in reset with toothpick or paper clip.
Then reprogram timer.
If you have Intermatic ST01C or EJ500 battery operated timer: Replace battery, then to reset timer: push-and-hold ON_OFF button, and then push reset button. Keep holding on-off button until display changes. Release on-off button and display will flash 12:00. Then reprogram timer.
If you have Utilitec astronomic timer, then press reset button and reprogram:
http://waterheatertimer.org/Program-wire-Utilitec-LW60419.html
No digital display, does that mean the battery is dead
You posted under Intermatic ST01C timer.
Display on this timer goes blank when new CR2 battery is needed and when timer has gone bad.
Many times when a new battery is installed, the timer has to be reset and then reprogrammed.
If timer cannot be reprogrammed after battery install, then timer has gone bad.
Open following links for ST01C resources: ez programming and reset instructions.
http://waterheatertimer.org/images/ST01C-battery-tray-0-400.jpg
The timer blinked low battery, we replaced the battery and now it needs to be reprogrammed but we have lost the manual. How do we reprogram it?
You posted under ST01C timer.
Open following page to read ez steps and download manual.
Unless you reset the timer, then programming will still be saved forever.
Even if battery was dead, programming remains saved inside timer until timer is reset or stops functioning.
So all you need to do is set current time.
If the timer will not work, then reset timer.
My ST01C works fine for a few days and then resets itself. The clock flashes 12:00am every time it resets and their is no pattern to it resetting. Sometimes it works for 2 days; sometimes 4-5. I reprogram...
My guess, it's the battery... Manual has troubleshooting steps that point to battery.
1) Timer requires CR2 battery to work ... double check markings on your battery. Programs will not function without battery. Battery can be low without BATT warning on screen.
2) ST01C has 1 year limited warranty. Things wear out.
3) When reprogramming, do you Reset timer? Or just reprogram Time-Date. Last-ditch troubleshoot says to Reset and Re-program timer.
1helpful
How do you reset the timer for a rainbird sprinkler system?
Resetting involves reprogramming, but that's easy to do. You probably have a cheat sheet, like I do.
Unplug the timer, remove the battery, and go have a cold drink (let it sit for about 10 minutes. Reinstall the battery, plug it back in and you are good to go. Reprogram.
Regards, --W/D--
Top Kichler Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Kichler Hardware and Accessory Expert? Answer questions, earn points and help others
