The Internet has a large number of web sites
where you can buy service manuals and schematics
from bookstores, publishers, and other collectors.
Factory Auto manuals
http://www.factoryautomanuals.com/
search for : factory service auto repair manuals
Repair Service auto Manuals
where to buy Factory Service Auto Repair manuals
http://www.repairservicemanuals.com/
the largest collection of Automotive Repair Service
Manuals and Owners Guides on the internet. Our
database currently holds over 54,000 entries dating
back from 1940 to more recent 2011.
Chilton Repair and Service Manuals
http://www.chilton.cengage.com/
Haynes Repair and Service Manuals
http://www.haynes.com/
Free Auto Service and Repair Manuals
http://free-auto-repair-manuals.com/
http://cars.lovetoknow.com/Free_Car_Repair_Manual
http://www.realworldautomotive.com/
https://www.2carpros.com/
SOURCE: Hi!!! I bought car with a grundig car 2002
Unfortunately your
code will not be available for free (or cheap) from anywhere on the Internet as this Serial
Number is not in the availableGRUNDIG database.
It
requires access to the original manufacturer`s database which is only available
from your Main Dealer .(and a few of the larger Professional Radio Decode
Specialists)
Otherwise
try a Decoding Service or your local Car Radio / Audio Shop who will electronically
"read "/ recode the memory chip (EEPROM) using a laptop and
specialist software.
Testimonial: "Thanks"
SOURCE: grundig car radio - car battery died - radio now
First make sure that the code has not been noted somewhere
within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here for free then the radio will have to be
removed from the dashboard (and if you are lucky, someone may have written the
code on the casing ) .
If not then POST A BRAND NEW QUESTION
quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on
ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
Also quote the MAKE of CAR
note: Unfortunately not all radios can be decoded using the
Serial Number
Otherwise try your Main Dealer ...........or take it into a
Decode Service who will plug in a laptop to read/recode the memory chip
(EEPROM). This takes a few minutes and shouldn`t be too expensive
SOURCE: grundig radio code
The radio will have to be removed from the car dashboard .
Then please quote the MAKE + MODEL of your radio plus ALL
the LETTERS and NUMBERS on any LABELS ,
BARCODES or STAMPED IN THE METAL CASING.
Also quote the MAKE of CAR it is fitted into.
SOURCE: i need a radio code for a phillips 400 car radio
Insufficient information to calculate a code
The SERIAL NUMBER required is 14 characters long , beginning with GM++++++++++++ and often found stamped in the metal casing
The one quoted only has 10 characters
