Sort of, but not easily, there is a screw just above the charging plug. it is covered by a plastic plug. You can remove the plastic plug, and unscrew the screw then pry off the grey plastic top cover. The battery is soldered to the control board. you would need to unsolder it and solder in new ones. they are 3 AAA size NiMH. You would need to buy a new set preferably with solder tabs on them, and then solder them in. In my unit, the battery was not the problem, i think the control board is poorly designed, and does not properly charge or control the battery and switch. My unit would not charge and even when it did, it only would run for about 4 minutes. I took the battery and control board out and hooked it up to a 5 volt battery which I charge with a radio control hobby grade battery charger. It works really well like this, but looks kinda gangsta.
