Nortel 2526T-PWR Ethernet Routing Switch with PoE - 24 x 10/100Base-TX LAN, 2 x 1000Base-T Uplink, 2... Logo
Posted on Jul 09, 2011
How can i reset switch 2526 T - PWR - Nortel 2526T-PWR Ethernet Routing Switch with PoE - 24 x 10/100Base-TX LAN, 2 x 1000Base-T Uplink, 2...
How to reset 3421 all ready try to off power and pwr on hold utilty then truble reset ok again pwr on but still same problem
IF THIS PROCEDURE DOES NOT WORK AND CODE COMES BACK DO NOT CONTINUE TO RESET THIS CODE IT DEALS WITH THE FUSER THE HOT PART IT CAN CATCH FIRE AND THAT WOULD RUIN A PERFECTLY GOOD DAY.
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check machine operates properly.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Code c-3B04
Fusing unit issue! Have to reset with PWR off the machine using both the main pwr inside front cover and sub pwr on the side of the op panel then turn on the machine holding down the Utiliy/counter button. unit the Trouble reset show on the screen then press trouble reset until says OK the Power off the machine with Main power switch inside the front cover, Wait ten seconds before doing that. If it comes back do not re do its broke and telling you so get a certified tech to look at it.
2answers
P1233 code ford contour
P1233 fuel pump driver module offline
4helpful
Confi stack on nortel switch 2526
Hi friend i want help can you give me the reply. i have 4 nortel 2550T-24 port switch but i don't know how to active stack config.
I need the wiring diagram for power,reset,lights
there is no need for the wiring diagram
if you check *********** board properly
you could find written in small font like
PWR SW for power switch
RST SW for rese switch
HDD LED , PWR LED etc
11helpful
4answers
8helpful
Front panel to motherboard, ASRock P4i65G, connections
the power switch is on the 3 and 4 pins....the 7 and 8 pin are the reset pins. Trying it on wrong pins just won't startup the board but won't short circuit anything.
Top Nortel Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
