Posted on Jul 09, 2011
Develop ineo 250 printer error is c3451 - Office Equipment & Supplies
Fayiz Elliyas
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 01, 2013
Fayiz Elliyas
Contributor
Level 1:
Answers
Questions
Helped
1974
Points
0
Mr. Ben thank you somuch. your helpful soluation
3 Related Answers
Anonymous
  • Posted on Jan 15, 2009
SOURCE: error c3451
First ignore the revious solution, it is not even close. The error code c3451 refers to a copier warm up error, the machine had not reached the correct temp within a specific time. I bet it happened when you first swiched on one morning. Easy to reset and fault usually goes away.
To Reset switch machine off using the switch inside the front door, not the one on the control panel.
Whilst holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen, touch this, OK will be displayed then power the machine off and then back on.
This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing.
hope this helps
Bizhubman
Ben
  • 108 Answers
  • Posted on May 19, 2010
SOURCE: bizhub 250 All-In-One Laser Printer: Error code C3451 wont reset using Utility key at s...
• The Fusing Roller Thermistor does not detect
the required temperature within 30 sec. after a
warmup cycle has begun; therefore, the copier
does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
You may have a bad fuser section. Another reset method is a small button located on the right side of the machine under on the scanner section. Locate your network port, then to the left of the port is a small cover that can be removed, behind that cover on the left is a small black button, use a paper clip or ball point pen and press the button, this will do a machine reset. When the operation panel abort starts to load hit the number 3 button, you should see a small back circle in the top right of the operation panel. This will give you the option to do a trouble reset.
If this does not work you will need a technician to come out and replace the fuser section, make sure they bring one with them so they don't have to reschedule and come back.
Anonymous
  • 60 Answers
  • Posted on Feb 24, 2011
SOURCE: How much is a fuser unit for a bizhub 250? I got a
around 250-280 $ (include shipping) but you may need a technician to clear counters, reset error code, and install and test the new fuser. If you want to do it by yourself, may be time consuming.....
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
