HP Photosmart Premium C309A  All-In-One Printer Logo
Posted on Jul 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CAN NOT DELETE A DOCUMENT THAT IS IN THE QUEUE, THEREFORE, NOTHING ELSE WILL PRINT. THE DOCUMENT SAYS IT IS DELETING, BUT DOES NOTHING. i POWERED IT OFF, THEN UNPLUGGED IT FOR A WHILE AND IT IS STILL STUCK. THIS HAPPENS A LOT WHEN I AM PRINTING WEB DOCUMENTS.
ONE-Touch-Solution
Level 3:
  • HP Master 1,679 Answers
  • Posted on Jul 02, 2011
ONE-Touch-Solution
HP Master
Level 3:
Answers
1679
Questions
Helped
413239
Points
5442
There are 2 simple methods to resolve any print job stuck in queue issue. However, both the methods will not fix printing issue if the HP Printer is in Error mode. Make sure your printer is able to print self test page to prove its functionality,
First method.
This Utility program resolve all the printing issue for HP Printers Only ( Network and USB connection )
This Utility will Resolve :
1. Check Connectivity between the Pc/laptop and HP Printer
2. Check if there any Documents stuck in Queue
3. Check if all the software/Drivers are correctly Installed
4. Check if the HP Printer icon is the default icon to print
5. Will Resolve Printer Spooler Issue and few more issue
Download the file on Desktop and Run the program ( Ex. File name = HPPDU.EXE )
Click Here to download the Utility and save on Desktop location
Run the HPPDU file and follow the instruction on screen to fix.
If this does not fix, try the 2nd Method given below ( this is manual process to clear the print job stuck in queue )
This works for all brands of printers ( HP, Canon, Epson, Brother etc )
Click Start > Programs > Accessories > then select Command prompt, then the black window will open and there type NET STOP SPOOLER and hit enter that will confirm service is stopped , after that on the black window type NET START SPOOLER and hit enter. Repeat this step 3-4 times and end the command with NET START SPOOLER and hit enter. Open the Printers folder and Refresh the Window ( Press F5 on the keyboard )
The service will be started and all print queue should already be remove.
// Above given solutions help in resolving print queue issue, however check the printer functionality if it is working fine ( the printer should be in working condition and should be able to print self test page, this utility cannot fix printer hardware issue //
Regards,
Ron
* Please rate this solution with Thumbs up and comment to help us improve providing support
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
