Zebra GK420t thermal transfer and thermal direct label , EPL and ZPL language, 4" 203DPI prin... Printer Logo
Posted on Jun 28, 2011
So we have a problem witch pront labels from SAP on Zebra GK420t printers , Pronters print margin witch are nowhere define and cut test ? Help. All configuration form SAP and prointer site look fine :( Regards Cezary.
4 Related Answers
Anonymous
  • 53 Answers
  • Posted on Dec 07, 2007
SOURCE: Print Width Issue
the issue you are having is DPI related, when data is sent to the printer and rendered it is dot for dot, so a Z4M 203dpi printer has about 800dots on the printhead where your printer has about 1200dots on the printhead. so when your software prints to dot800 thinking it is the edge of the label it is infact at 60%. there sould be an option in the software to configure around this. if not the is an option in the printer to convert DPI setting ie 150>300 or 100>200 and so on. but i don't thing you can make a 300dpi print as 203dpi
best of luck
Bubbabear64
Tim Babcock
  • 2794 Answers
  • Posted on Jul 29, 2008
SOURCE: Zebra TLP 2844-Z Test page print within Win XP
This printer requires special software to print labels with. It uses a unique PCL language to work with. Thats why when you use these printers with Fedex or UPS software, it typically downloads forms first before working.
Zebra used to see a label designer program to work with it. You might want to check with them to see if they still carry it.
Anonymous
  • Posted on Mar 11, 2009
SOURCE: prints out 2 labels at once
I've seen this be due to dirty sensor or misconfigured media setting.  Clean the sensor in the middle of the edge on the inside and outside of the printer, then if still having trouble - Inside the printer it should tell you that if you are having printing trouble:
  1. turn off the printer
  2. Hold down the feed button
  3. turn on the printer and at the third red flash release the feed button
  4. it will then feed some pages print some info and ask you to hit feed again to exit dump
  5. hit feed again and it will say exiting dump
You have just made it reconfigure media, and it may know when to stop feeding now.
Anonymous
  • 50 Answers
  • Posted on Jul 25, 2011
SOURCE: I have a Zebra GK420t Alternately Flashing Red and
From the owner's manual:
Alternately Flashing Green and Red: Needs Service 8
8. FLASH memory is not programmed.
• Return the printer to an authorized reseller
You can find the complete owner's manual on Zebra's web site.
Top Zebra Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
jdthefixer
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
