Check to see if the map is installed.
To view the maps loaded on your unit and their version, touch Tools > Settings > Map > Map Info.
If not, you may need to downlaod or purchase a new one. Instructions are on page 24 of the manual, which can be viewed below:
http://static.garmincdn.com/pumac/nuvi_1100_1200_1300_1400_OM.pdf
SOURCE: Nuvi 205w won't read upgraded map
You HAVE to go through software support as this is an issue with the map. They told me it is because the map KEY is wrong, it is only for the united states, but the map is ALL of north america. The wait time is incredibly long, I have been waiting for over an hour, such bad service
SOURCE: Garmin Nuvi 205 can't unlock maps
First, check to make sure the map file is there. The file name is gmapprom.img. It's located in the Garmin directory. It should be 1GB in size. To do this you need to connect the Nuvi to a PC with a USB cable.
Next, please tell me what year of map you have on your unit, 2009, 2010, etc.
Them, email me your units internal serial number. Its a 10 digit number (not the number on the outside). The number starts with a "3" and can be found by pressing the tools button, then system and then "about".
Please email me at sharcnet-usa AT sharc DOT NET
- Jim
SOURCE: the garmin nuvi 1300 series comes on and then says...
A Garmin Nuvi 1300 that freezes on 'loading maps,' or is
acting erratically is symptomatic of having corrupt
firmware.
To
correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck,
then updating your Nuvi firmware.
Follow
these three steps to take to get
your Garmin Nuvi 1300
running like new:
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
SOURCE: I tried downloading a map
These are the instructions for unlocking maps from the Garmin website:
Safely disconnect your Garmin device from the computer to complete the process. If you are having any issues duplicating the steps above or are still receiving the message "Can't unlock maps, your unit will not function without maps” please contact Product Support.
1 The device must be registered to view the Unlock Code.
2 In My Computer, some units may be labeled 'garmin (drive letter:)'.
SOURCE: i cant find out how to unlock the europe map on my
Details on how to unlock your map are at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing
There may be more information there than you need so skip to the part you need.
