OKI Microline 3410 Matrix Printer Logo
Posted on Jun 28, 2011
I have a problem with a oki microline printer, it shows something like inverted commas and other funny text when printing payslips.
4 Related Answers
Anonymous
  • 32 Answers
  • Posted on Feb 15, 2008
SOURCE: Problem with oki microline 395
Enter the menu,
Change Language set to American. It is under symbol sets. Also change code page to usa.
Menu Mode
1. Verify that paper and the ribbon are installed.
2. Power ON the printer4.gif.
3. Press SELECT and place the printer OFF-LINE (SELECT will not be lit).
4. Press QUIET to enter Menu Mode.
5. The line shown below will print4.gif.
Printer Control Emulation Mode Epson LQ 6. Go to Step A to print the current menu.
Go to Step B to change the menu.
Step A
Press PRINT to print the current Menu.
Press EXIT to exit Menu Mode.
The printer will go ON-LINE. (SELECT will light.)
Step B
Press GROUP to move through the groups of the Menu.
A line prints4.gif, showing the Group.
Press ITEM to move through the items in a group.
A line prints, showing the Item.
Press SET to change the setting for an item.
A line prints, showing the Setting.
Anonymous
  • Posted on May 23, 2008
SOURCE: Alarm light Microline 320 Turbo 9 pin printer - won't print
We swapped out the printer for another one we had in the office that was working. The new printer also got the alarm light. From that we concluded that it was a bad serial card. We swapped the serial card from another printer, and the original printer started working perfectly. Now we just need to find out where we can purchase another serial card, as we have no more 'spares' around here.
Anonymous
  • 5 Answers
  • Posted on Mar 05, 2009
SOURCE: Oki Microline 590
Try to perform an offline test print using your printer alone
To do this, power off your printer first
Press and hold the LF/FF button on the printer panel then power on. The printer will perform its own printing ( lines of pattern )
If it does it without problems ( no MENU lights came on ) the printer should be OK. If not try replacing the printer main control board.
Hope this helps
KM Hoo
It
Renierf
  • 97 Answers
  • Posted on May 12, 2009
SOURCE: Oki Microline 520 printing slow
Re-seat your Printhead. If problem persists Replace the Main Board.
Top OKI Office Equipment & Supplies Experts
George Mclaughlin
Grand Canyon Tech
Grand Canyon Tech
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
