Hello!
Sign in failure can be caused not only by the camera or Skype, but also by slow connection.
You first need to make sure that your camera is functional. Please, follow these steps and open these two windows:
Make sure your webcam is selected in Skype settings so that Skype can use it:
If you experience issues like signing in to your Skype is taking too long, Can't sign in, or you can't see or hear the other person, then you should contact your internet provider for slow connection. Also, you can check your connection using Speed Test online (www.speedtest.net).
Regards!
1st You download Webcam Driver.
install my camera
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Logitech Camera Drivers for Windows XP Vista Windows 7
SOURCE: Why can't i log on ooVoo anymore?
http://oovoo.com/
http://oovoo.com/
The first is correct... the second is incorrect. This should solve your dilemma with not being able to get to the website.
For the other problem. Try deleting the software then reinstalling it.
If it still doesn't work, disable your firewall program because it is probably blocking the connection.
SOURCE: when i try to sign on to oovoo it says failed to
Can anyone help with solving this problem. I have the same difficulty.
