Computers & Internet Logo
Posted on Jun 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can i open my dell 1707FP monitor - Computers & Internet
  • Paul Petty Jun 20, 2011
    what exactly do you mean by "open", do you want to open the menu, open the monitor up? Im confused by your wording.
Anonymous
Level 2:
Sergeant:
  • Expert 318 Answers
  • Posted on Jun 22, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
318
Questions
0
Helped
46717
Points
871
Using a screw driver
How to fix my Dell 1707fp monitor screen goes black after a few seconds when turn power on?
could be what they call the inverter and that is behind the screen at the bottom.
How to open dell lcd monitor case 1707FP c
I made a video of repairing my E178FBb and I show how to take it apart. I assume it comes apart the same as yours.
It is a Dell monitor, Model 1707FP. The screen went black and the power button is blinking. It does not make a difference whether I disconnect the video cable or connect it to another computer. What are...
http://s807.photobucket.com/albums/yy352/budm/Dell%201707FP%20Rev%20A01/
Check for bad caps first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you
http://www.badcaps.net
Replacement board:
http://www.lcdrepair.us
1helpful
On off switch on 1707fp moniter not working . I need a new switch. Where can I get one/
Try mouser electronics. You shouldn't have any trouble finding a replacement. Be careful if you open up the monitor though. There are parts in there that can electrocute you even after it's been unplugged.
Dec 07, 2009 • GPS
1helpful
Power button damange ,
I used two thin putty knives this morning to open the monitor case. First, unscrew the four screws at the back. Then insert a putty knife into the small crack between the front bezel and the monitor shell. Carefully work you way around and wiggle the putty knives. Note that the front buttons are attached to the thin black edge at the front, and there's a thin cable at the bottom. Don't damage that. You can take off the back shell though.
Can't power on my DELL 1707FP monitor
Try a different wall outlet. If no go swap the monitor and tower power cables. I still no joy disconnect the power cord from the monitor, hold the power button for 10 seconds with the power cord disconnected. Try Plugin intu cable. If the screen is still dead check with dell tech support if the monitor has a warranty active on it. If the warranty is out get the monitor checked at a local computer shop.
Power on/off button not working on Dell 17 in. Ultrasharp 1707FP
hi. probably de botton is damage or broken. if you have experience opening electronic devices like monitor you can replace that button you can purchase online. depending on the type of button, you can see a full tipe of button here: https://www.sparkfun.com/categories/145?page=all
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
