SOURCE: GETTING ERROR "ron"
If we are talking about a conair weight watrchers sclae i contacted manufacturer as this is quite the little eppidemic I have 3 of you with same problem. here is the response unfortunately i had contacted the canada location and not the us so i will provide the contact info for the us after the response. The unti is under a 10 year warrenty and usually warrenties are void if you mess with the unit so I highly reccomend you contact them first.:
Thank you for your email.
Simply mail us your defective product or part with a detailed letter stating your name,mailing address, model , serial number, a brief description of the problem , a photocopy of your receipt and a cheque made out to Conair Canada for Conair products($5.00) or Cuisinart Canada for Cuisinart products ($10.00) for return shipping. Your product will be serviced and or inspected for possible warranty repair or replacement.
Please note that all replacements will take from 3-6 weeks and will not be replaced immediately. They must go through are technical department for testing.
Please also be advised that we do not have a reimbursement or refund policy.
CONAIR/CUISINART CONSUMER PRODUCTS
100 Conair Pkwy
Woodbridge ON
L4H 0L2
Tel: 1-800-472-7606
Sorry for any inconvenience this may cause.
Regards,
Consumer Service Representative-CP
Conair Corporation
Service Department
150 Milford Road
East Windsor, NJ 08520
Conair Corporation
Service Department
7475 N. Glen Harbor Blvd.
Glendale, AZ 85307
1-800-326-6247
www.conair.com
and your warrenty if for 10years sorry for confusion
Conair will repair or replace, at our option, your appliance free of charge for
120 months from the date of purchase if the appliance is defective in
workmanship or materials.
To obtain service under this warranty, return the defective product to the service
center nearest you, together with your sales slip and $5.00 for postage and
handling. California residents need only provide proof of purchase and should call
1-800-3-CONAIR for shipping instructions. In the absence of a receipt, the
warranty period shall be 120 months from the date of manufacture.
ANY IMPLIED WARRANTIES, OBLIGATIONS, OR LIABILITIES, INCLUDING BUT NOT
LIMITED TO THE IMPLIED WARRANTY OF MERCHANTABILITY
AND FITNESS FOR
A PARTICULAR PURPOSE, SHALL BE LIMITED IN DURATION TO THE 120 MONTH
DURATION OF THIS WARRANTY. Some states do not allow limitations on how long
an implied warranty lasts, so the above limitations may not apply to you.
IN NO EVENT SHALL CONAIR BE LIABLE FOR ANY SPECIAL, INCIDENTAL, OR
CONSEQUENTIAL DAMAGES FOR BREACH OF THIS OR ANY OTHER WARRANTY,
EXPRESS OR IMPLIED, WHATSOEVER. Some states do not allow the exclusion or
limitation of special, incidental, or consequential damages, so the above limitation
may not apply to you. This warranty gives you specific legal rights, and you may
also have other rights which vary from state to state.
SOURCE: The Homedics SC 380 scale does not work after the battery insert
ensure the battery contacts are clean, if they are corroded it wont work. You may have to buy a contact cleaning spray or brush to do it.
SOURCE: The Homedics SC 380 scale said low battery. After
The same happened with me, but here is what I did and it worked. I took the new battery out and set the setting on the bottom of the scale to Stone, put the battery back in. Now when I put the battery back in I made sure the plus on the battery was the last part to go in, it faced the part inside the casing that needs to be pushed back when you take out the battery. Once it was in I put the setting back to LBs and it worked. Don't know how but I was just as frustrated and it worked.
SOURCE: I have a salter electronic
well those are indeed batteries but may need de-soldering in order to have them replaced in which case you will have to get a soldering gun. hope that helps.
