If you are vacuuming a lot of debris or algae, you need to vacuum to waste. 1. You'll turn the equipment off, 2. You'll turn the valve to waste, 3. Turn the equipment back on, and 4. Vacuum the pool like you normally would. Only this time, the debris and dirty water goes out your backwash/waste line. You also don't have to backwash and rinse afterward because none of the debris went inside the filter.
Any time you vacuum up just a small amount of debris, you'll vacuum on filter and then backwash (30-60 seconds) and then rinse (about 30 seconds).
