AT&T E5813B Trio Cordless Phone Logo
Posted on Jun 09, 2011
I am having a problem with my AT&T cordless phone, 5.8 GHz, Model E5813B. I can't get the phone to connect to the base. I keep getting the message on the screen that the phone is connecting and other handset is on or out of range. They are not on or out of the range. The other handsets are not connected because they don't even have batteries in them.
5 Related Answers
Anonymous
  • 513 Answers
  • Posted on Jun 05, 2006
SOURCE: "searching" message even when handset on the base
Found the following in AT&Ts FAQs for your phone, I'll leave only what might be relevant: # Charge the handset for 12 hours. After the first charge, the battery will quick charge in only 8 hours. Re-cradle the handset nightly for recharging. The battery will not overcharge. # Connect telephone line from base to unit to modular telephone jack. If cord is already plugged in, unplug and reconnect at both ends. Also, you may want to try another cord from a working telephone. See the owner's manual under "Connecting to Phone Line." (you can get the manual here on the product page in case you lost it) # Try a working phone at the jack. If another phone has the same problem in that jack, the phone jack is defective. Good luck, hope you work it out
Anonymous
  • Posted on Dec 14, 2007
SOURCE: 5.8 ghz mulit-handset cordless phone
How do you get the ringer on this phone to work?
A
Anonymous
  • Posted on Mar 24, 2008
SOURCE: AT&T Model # 1487 Phone
http://telephones.att.com/telephones_ui/support/support_index.cfm
Go to the above web site. It helped me.
Anonymous
  • Posted on Jul 06, 2008
SOURCE: out of range shows on main handset of cordless phone
Unplug the battery. Hold down The * (star) and the #(hash) keys simultaneously. Re-connect the battery, phone will beep and screen will be blank. Press the voicemail (righthand silver key under the lcd screen). As above EEPROM/RAM message will appear. Place handset on base and your problem is solved.
Anonymous
  • 82 Answers
  • Posted on Oct 14, 2008
SOURCE: Uniden 5.8 GHz Digital cordless w 3 handsets interference background noise no matter where we are in the house or which handset we use
This is possibly caused by the internet connection.
Try new ADSL filter.
You need one each per device.
Top AT&T Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
