Samsung DV218AEW Electric Dryer Logo
Linford House Posted on Jun 04, 2011
Have E5 error code. Took dryer apart cleaned filter blower & ducts. Checked resistance of heater element reads 9.7 ohms. Thermistor readings seem normal. After reassembling still get E5 error code. Dryer was purchased in 04/2009.
5 Related Answers
Anonymous
  • 27 Answers
  • Posted on Jun 29, 2008
SOURCE: Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Anonymous
  • 324 Answers
  • Posted on Nov 23, 2008
SOURCE: Dryer heating element(s) are inconsistent
there is only 1 element. were you taking these readings with the wires on them?
the other 2 were thermostats.was there lots of lint?
sounds like you may have bad thermostat.
Bill Eager
  • 460 Answers
  • Posted on Mar 11, 2010
SOURCE: Does no heat.Have checked heating element.Have
Did you check the thermal fuses
Continuety is all you need.
Be sure to unplug them from the system before testing otherwise you can get a good reading coming back from another path through the dryer
TheMobilian
Dan Webster
  • 8221 Answers
  • Posted on Jul 14, 2010
SOURCE: Dryer will not shut off in any 'auto' mode.
How long is the vent from the dryer to the outside? Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dry-ability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
kel1guy2002
Kelly
  • 3740 Answers
  • Posted on Oct 13, 2010
SOURCE: I could not find the ohm readings for the
Hi and welcome to FixYa. I am Kelly.
Look inside the back of the dryer. Most Samsung dryers have a tech sheet in a clear envelope usually in the back of the dryer. The thermistor values are on the tech sheet.
I am pretty sure this is the number for it but.... not 100% PN: DC32-00007a.
Thanks for choosing FixYa,
Kelly
Top Samsung Dryers Experts
gerbee gomez
Paul Bade
vince
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
