Nexgrill 720-0234 (LP) Logo
Posted on Jun 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have been using the grill for about a year now. All of a sudden the electronic igniter dosen't spark on all control knobs. I checked the battery and replaced it with a new one. It did not change anything. Is there a spark generator that can go bad? Just need help. Thanks Bud
Anonymous
Level 1:
New Friend:
  • Contributor 7 Answers
  • Posted on Jun 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
7
Questions
0
Helped
3505
Points
23
The spark works by using a ground wire or the ignitor touching the grill cabnet. You might net to cleam the ignitor and also check the wire to the ignitor. The screw that holds the ground may be loose.
Anonymous
Level 3:
Brigadier General:
  • Master 4,736 Answers
Anonymous
Master
Level 3:
Brigadier General:
Answers
4736
Questions
0
Helped
2144011
Points
14644
First, Bud make sure the battery was installed facing the proper direction. The Positive end (+) should be facing out when installed. If that's not the problem, check the wiring from the ignition module to the each burner ignitor. One may be loose or the grounding wire from the ignitor module to the grill's frame, may have lost contact. Also, look carefully at each ignitor tip at the burners. They may have an accumulation of grease, which needs to cleaned off.
If all that doesn't resolve the problem, you will need to replace the ignitor module. You can purchase one online directly from NEX Grill http://www.nexgrill.net/ or from Factory Appliance Parts
http://www.appliancefactoryparts.com/search/index.php
Hope this helped you troubleshoot and solve the problem. Please let me know and Happy Grilling!!
Top Nexgrill Grilling Experts
Paul Carew
Dennis
ADMIN Andrew
ADMIN Andrew
Are you a Nexgrill Grilling Expert? Answer questions, earn points and help others
